[postgis-users] GEOS / Predicates Update
Paul Ramsey
pramsey at refractions.net
Thu May 22 09:45:15 PDT 2003
PostGIS'ers,
It has been a while since I told you all that predicates would be
available in PostGIS "soon", so I think I should provide an update.
a) the GEOS library supports the spatial predicates and a few of the
operators (geos.refractions.net) and has been tested against a pretty
comprehensive test harness. GEOS seems to be ready to go.
b) the CVS version of PostGIS includes support for building in GEOS
and a relate() function available in SQL. The current implementation
does not do very good memory management, so repeated invocations of the
GEOS functions will leak memory into the postgres instance over time.
c) we have been unable to implement proper exception handling in
PostGIS for GEOS exceptions. This is a BIG PROBLEM. GEOS throws
exceptions for things it cannot handle topologically, primarily for
illegal geometries. Ideally, PostGIS would catch these exceptions and
translate them into PostgreSQL errors or warnings, depending on
severity. This is how Dave designed his implementation. However,
there appear to be some low level bugs in C/C++ interaction which cause
exceptions thrown by GEOS to be interpreted by the parent process
(postgres) as SIGABORT, which shuts down the backend immediately. The
net effect is that any exception GEOS hits causes the backend to
immediately terminate, instead of handling the exceptions. No amount
of repositioning of the exception handling code has fixed this. We have
put the exception handling right back into the GEOS library, and the
result is still the same -- as soon as an exception is raise, the
backend terminates.
Dave has already posted a detailed technical description of the
problem to this list.
We are at a bit of an impasse right now, because there seems to be no
fast-and-easy way to avoid this problem. Our current options appear to
be:
- Try the very latest gcc, glibc, and libstdc++ libraries and see if
the problem has been resolved. It has been reported to the maintainers
about a year ago, as far as we can tell. While this might fix the
problem, it will make deployment very difficult for people, since
almost no linux distributions have the very latest versions of these
libraries. Commercial UNIX'es will also be terra incognito.
- Re-write some chunks of GEOS to not throw exceptions. This is bad
for two reasons. It is a large amount of work, and it also is bad
design. The exceptions are there for a reason, and replacing them with
large chains of null handling will be unpleasant. There are some
"exception emulation" libraries for C which could make the process less
unpleasant, but it will still not be nice at all.
- Re-write GEOS entirely, and again, in C. This at least would be a
clean implementation of the algorithms, but it is even more work, and
would constitute yet another port of JTS which would have to be kept
synchronous with the JTS R&D over time.
All the options suck, which is why we have not chosen one yet.
That's the state of things now,
P.
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
