[postgis-users] GEOS / Predicates Update
David Blasby dblasby at refractions.net
Thu May 22 10:37:01 PDT 2003
C F wrote:
> - PostgreSQL is written in C and GEOS is written in C++ and that's
> what's causing the discrepancies in exception handling, is that right?
Yes - but its a bit more complex.  Its only a problem if the chain looks
like this (3 steps):
C (postgresql) -> [dynamic load] PostGIS (C) -> GEOS (C++)
> - You probably have, but just to double check... have you guys tried the
> PostgreSQL lists with this problem?
Yes - they said to try the newer compiler/libaries or build postgresql
using the c++ standard libary instead of the c standard library.
> - You mentioned that one solution may be to use newer compilers.  Would
> that mean that all three components (PostgreSQL, GEOS and PostGIS) would
> need to be compiled with these?  Correct me if I'm wrong, but that
> doesn't seem like a big deal to me.  Wouldn't that just be a matter of
> downloading the latest compilers and recompiling these things *IF* you
> want GEOS support (which I do)?  Or am I over simplifying..
We are trying to make it as simple as possible for people - most people
will find it difficult to update their machines.
dave
