[postgis-users] Unable to make PostGIS in Cygwin
Mike Leahy
mgleahy at fes.uwaterloo.ca
Tue May 27 12:30:26 PDT 2003
Hello all,
Although we have a complied version of PostGIS, I am trying to see if I
can compile it myself within Cygwin using the directions in the Windows
PostGIS Installation Guide available on the refractions.net
documentation page. I seem to be nearly there.except for some kind of
error when I run 'make' for PostGIS (immediately after I run 'make' for
PostgreSQL). You can see the error I'm getting at the end of the
process below. Any suggestions some of you might have would be great.
Mike
Administrator at mgl-toshiba
/usr/src/postgresql-7.3.2-2/contrib/postgis-0.7.5
$ make
gcc -O2 -Wall -Wmissing-prototypes -Wmissing-declarations -g -I.
-I../../src/in
clude -DFRONTEND -DSYSCONFDIR='"/etc/postgresql"' -DUSE_VERSION=73 -c
-o postg
is_debug.o postgis_debug.c
-I../../src/in
-o postg
is_ops.o postgis_ops.c
-I../../src/in
-o postg
is_fn.o postgis_fn.c
-I../../src/in
-o postg
is_inout.o postgis_inout.c
-I../../src/in
-o postg
is_proj.o postgis_proj.c
-I../../src/in
-o postg
is_chip.o postgis_chip.c
-I../../src/in
-o postg
is_transform.o postgis_transform.c
postgis_transform.c: In function `transform_geom':
postgis_transform.c:437: warning: control reaches end of non-void
function
-I../../src/in
-o postg
is_gist_72.o postgis_gist_72.c
-I../../src/in
-o postg
is_estimate.o postgis_estimate.c
dlltool --export-all --output-def postgis.def postgis_debug.o
postgis_ops.o post
gis_fn.o postgis_inout.o postgis_proj.o postgis_chip.o
postgis_transform.o postg
is_gist_72.o postgis_estimate.o
dllwrap -o postgis.dll --dllname postgis.dll --def postgis.def
postgis_debug.o p
ostgis_ops.o postgis_fn.o postgis_inout.o postgis_proj.o postgis_chip.o
postgis_
transform.o postgis_gist_72.o postgis_estimate.o
../../src/utils/dllinit.o -L/us
r/local/lib -L/usr/local/lib -L../../src/backend -lpostgres
fu000001.o(.idata$3+0xc): undefined reference to `_libpostgres_a_iname'
nmth000000.o(.idata$4+0x0): undefined reference to
`__nm__cpu_index_tuple_cost'
Info: resolving _cpu_index_tuple_cost by linking to
__imp__cpu_index_tuple_cost
(auto-import)
collect2: ld returned 1 exit status
dllwrap: gcc exited with status 1
make: *** [libpostgis.a] Error 1
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20030527/162cc06d/attachment.html>
