[postgis-users] side location conflict in GeomUnion function
Hisaji Ono
hi_ono2001 at ybb.ne.jp
Thu Nov 13 21:30:03 PST 2003
Thank you very much, Paul.
I've resolved this problem using "magical" Buffer function as follows.
select GeomUnion(Buffer(the_geom,0)) from kagawa group by y2000;
But island polygons were vanished, if these necessary, I should regenerate
these ones using Difference function.
> Have you checked that all your geometries are valid first?
> select * from geomtable where not isvalid(the_geom);
> invalid geometries are the #1 cause of topology failures.
