[postgis-users] Create View with PostGis table
OpenGis opengis at libero.it
Fri Nov 14 04:39:19 PST 2003
chodgson at refractions.net wrote:
>Do you really need to use a view? Did you know that it is possible to specify
>more complicated queries in the mapserver config file?
>Read this:
>http://postgis.refractions.net/docs/x552.html#AEN610
[0]
    DATA "the_geom from v_land_t as foo USING UNIQUE oid USING
SRID=-1"    # OK
where v_land_t:
CREATE VIEW v_land_t AS SELECT t0.oid, t0.*, phone FROM landusea_region
t0, tab_zu where t0.name= tab_zu.nm;
[1] -- very simple--
 DATA "the_geom FROM (SELECT the_geom, oid FROM landusea_region) AS foo
USING UNIQUE oid USING SRID=-1"
[2] -- quite simple--
 DATA "the_geom FROM (SELECT the_geom, oid FROM landusea_region WHERE
landusea_region.gid < 10) AS foo USING UNIQUE oid USING SRID=-1"
 [3]-- more complex--
 DATA "the_geom FROM (SELECT landusea_region.the_geom AS the_geom,
landusea_region.oid AS oid, tab_zu.phone AS phone FROM landusea_region,
tab_zu WHERE landusea_region.name = tab_zu.nm) AS new_table USING UNIQUE
oid USING SRID=-1"
For [1] (but same behavior for [2] & [3])
in mode=browse
Server error!
The server encountered an internal error and was unable to complete your
request.
Error message:
Premature end of script headers: mapserv
in mode=query
prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual
query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(8B8B)),'NDR'),oid::text
from @B@B WHERE 8B8B && setSRID('BOX3D(12.4496
41.8826186666667,12.452 41.8850186666667)'::BOX3D, -1 )'
Postgresql reports the error ''
More Help:
Error with POSTGIS data variable. You specified '<check your .map file>'.
Standard ways of specifiying are :
(1) 'geometry_column from geometry_table'
(2) 'geometry_column from (<sub query>) as foo using unique <column
name> using SRID=<srid#>'
Make sure you put in the 'using unique <column name>' and 'using SRID=#'
clauses in.
For more help, please see http://postgis.refractions.net/documentation.php
Mappostgis.c - version of June 12/2003.
msPOSTGISLayerParseData(): Query error. Error parsing POSTGIS data
variable. Must contain 'geometry_column from table_name' or 'geom from
(subselect) as foo' (couldnt find ' from '). More help:
Error with POSTGIS data variable. You specified 'the_geom FROM (SELECT
the_geom, oid FROM landusea_region) AS foo USING UNIQUE oid USING SRID=-1'.
clauses in.
>>>My landusea_region table:
>>>Field		Type
>>>gid 		int4
>>>polygon_id 	int8
>>>name 		varchar
>>>langcode 	varchar
>>>type 		varchar
>>>city 		varchar
>>>the_geom 	geometry
0   | 50987009   | VILLA DORIA PAMPHILI  | ITA  |PARK (CITY/COUNTY)  |
Y  | SRID=-1;MULTIPOLYGON(((12.43724 41.88032,12.4366 41.88037,12.43621
41.88041,12.43609 41.88047,12.43536  .......
What do you think? Is it possible PostGis bad configuration (but work
fine in other condition)?
Any clue?
Thanks in advance
opengis (at) libero (dot) it
AOL: open2gis
