[postgis-users] windows 2000 install
Tyler Mitchell
TMitchell at lignum.com
Mon Nov 17 08:31:31 PST 2003
This thread should help:
http://postgis.refractions.net/pipermail/postgis-users/2003-June/002585.html
You need to modify a file and remake.
Tyler
postgis-users-bounces at postgis.refractions.net wrote on 11/15/2003 06:42:09
AM:
> Hi list,
> I am trying to install PostGIS on Windows 2000. I followed the steps
> http://postgis.refractions.net/windows/WindowsHowTo.html
> 2 remarks on this WindowsHowTo:
> a. the cygipc part is a bit outdated, I am using the latest cygwin in
which
> cygipc 2 is included. But statements like $ ipc-daemon &
> should be changed into:
> $ ipc-daemon2 &
> b. when downloading cygwin you do not get the PostGreSQL source. So this
> needs to be downloaded as well and fitted into the
> cygwin\usr\share\postgresql directory. This part is not mentioned in the
> WindowsHowTo.
> But now am I running into a problem with make for PostGIS.
> Administrator at client /usr/share/postgresql/contrib/postgis-0.7.5
> $ make
> gcc -O2 -Wall -Wmissing-prototypes -Wmissing-declarations -g -I. -
> I../../src/in
> clude -DFRONTEND -DSYSCONFDIR='"/etc/postgresql"' -DUSE_VERSION=73 -c
-o
> postg
> is_debug.o postgis_debug.c
> I../../src/in
-o
> postg
> is_ops.o postgis_ops.c
> I../../src/in
-o
> postg
> is_fn.o postgis_fn.c
> I../../src/in
-o
> postg
> is_inout.o postgis_inout.c
> I../../src/in
-o
> postg
> is_proj.o postgis_proj.c
> I../../src/in
-o
> postg
> is_chip.o postgis_chip.c
> I../../src/in
-o
> postg
> is_transform.o postgis_transform.c
> postgis_transform.c: In function `transform_geom':
> postgis_transform.c:437: warning: control reaches end of non-void
function
> I../../src/in
-o
> postg
> is_gist_72.o postgis_gist_72.c
> I../../src/in
-o
> postg
> is_estimate.o postgis_estimate.c
> dlltool --export-all --output-def postgis.def postgis_debug.o
postgis_ops.o
> post
> gis_fn.o postgis_inout.o postgis_proj.o postgis_chip.o
postgis_transform.o
> postg
> is_gist_72.o postgis_estimate.o
> dllwrap -o postgis.dll --dllname postgis.dll --def postgis.def
> postgis_debug.o p
> ostgis_ops.o postgis_fn.o postgis_inout.o postgis_proj.o postgis_chip.o
> postgis_
> transform.o postgis_gist_72.o postgis_estimate.o
../../src/utils/dllinit.o -
> L/us
> r/local/lib -L/usr/local/lib -L../../src/backend -lpostgres
> fu000001.o(.idata$3+0xc): undefined reference to `_libpostgres_a_iname'
> nmth000000.o(.idata$4+0x0): undefined reference to
> `__nm__cpu_index_tuple_cost'
> Info: resolving _cpu_index_tuple_cost by linking to
> __imp__cpu_index_tuple_cost
> (auto-import)
> collect2: ld returned 1 exit status
> dllwrap: gcc exited with status 1
> make: *** [libpostgis.a] Error 1
> I am using postGIS 0.7.5 in conjunction with PostgreSQL 7.3.4 and the
> latest Cygwin.
> Does anybody have an idea what is going wrong?
> Best regards and thanks in advance.
> Bart
> postgis-users mailing list
