[postgis-users] Query for all the polygon tables
Matt Lynch
matt at terraEngine.com
Wed Nov 19 10:28:40 PST 2003
Hi Chris,
Thanks! That did the trick.
Matt
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
chodgson at refractions.net
Sent: Wednesday, November 19, 2003 11:10 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Query for all the polygon tables
If you haven't figured this out already, try this:
SELECT DISTINCT f_table_name FROM geometry_columns;
HTH.
Chris
Quoting Matt Lynch <matt at terraEngine.com>:
> Hi Paul,
> I have used addgeometry column for all my tables, so how would I do
> the query?
> Thanks,
> Matt
> Paul Ramsey
> Sent: Tuesday, November 18, 2003 2:40 PM
> Subject: Re: [postgis-users] Query for all the polygon tables
> If you manage your columns carefully using addgeometrycolumn and
> dropgeometrycolumn, you should be able to do this with a trivial query
> against GEOMETRY_COLUMNS.
> Paul
> Matt Lynch wrote:
> > Hi,
> > I would like to be able to query for all the polygon tables in a
> > specific postgis database.
> > I dug around on the net and figured out how to find all the tables,
> > that is
> > SELECT c.relname, 'table'::text, u.usename FROM pg_class c,pg_user u
> > WHERE c.relowner = u.usesysid AND c.relkind='r' AND NOT EXISTS
> > (SELECT
> > 1 FROM pg_views WHERE viewname=c.relname) AND c.relname !~ '^pg_';
> > Now I need some help to restrict to the polygon tables.
> > Any suggestions?
> > Thanks,
> > Matt
> > Outgoing mail is certified Virus Free.
> > Checked by AVG anti-virus system (http://www.grisoft.com).
> > Version: 6.0.532 / Virus Database: 326 - Release Date: 10/27/2003
> > postgis-users mailing list postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
> Incoming mail is certified Virus Free.
