[postgis-users] Troubles in the installation
strk strk at keybit.net
Thu Nov 20 01:07:31 PST 2003
Please set you LANG=C
Althought localization might be a good thing for those who have problems
learning a spread foreign language as English, it does also divide
the world splitting people by country, which is no more useful in
our actual network society :)
To be more pragmatic: your problems expressed in spanish will have
less chances to be solved by a multi-cultural community.
PS: try also postgis-0.7.5 ...
--strk;
ing_talledo wrote:
> I am trying to install the postgis7.4 into the postgresql 7.4, but when I do
> make i have this problem:
> [root at gis001 postgis-0.7.4]# make
> gcc -O2 -fno-strict-aliasing -Wall -Wmissing-prototypes
> -Wmissing-declarations -fpic -g -I. -I../../src/include -D_GNU_SOURCE
> -DFRONTEND -DSYSCONFDIR='"/usr/local/pgsql/etc"' -DUSE_VERSION=73  -c -o
> postgis_estimate.o postgis_estimate.c
> postgis_estimate.c: En la función `get_restriction_var':
> postgis_estimate.c:543: aviso: asignación de tipo de apuntador incompatible
> postgis_estimate.c:545: aviso: asignación de tipo de apuntador incompatible
> postgis_estimate.c: En la función `genericcostestimate2':
> postgis_estimate.c:752: structure no tiene un miembro llamado `elem'
> postgis_estimate.c:752: muy pocos argumentos para la función
> `clauselist_selectivity'
> postgis_estimate.c:810: aviso: pasando el argumento 1 de `cost_qual_eval' de
> postgis_estimate.c:810: muy pocos argumentos para la función
> `cost_qual_eval'
> postgis_estimate.c:810: valor void no ignorado como debería de ser
> make: *** [postgis_estimate.o] Error 1
> could you help me with this.
> Thanks
> _________________________________________________________________
> MSN Amor: busca tu ½ naranja http://latam.msn.com/amor/
> postgis-users mailing list
