[postgis-users] Troubles in the installation
strk
strk at keybit.net
Thu Nov 20 04:53:13 PST 2003
holgerzebner wrote:
> ---> can't find file ../../src/Makefile.global:
You need postgresql source available in order to build postgis.
Once you have it either unpack postgis sources under PGSRC/contrib
*or* modify the PGSQL_SRC variable on top of master postgis Makefile
to point to postgresql souce directory.
Note that postgresql source must be properly configured and must
match the installed one.
--strk;
