[postgis-users] GeomFromWkb() incomplete?
Martin Schäfer
Martin.Schaefer at cadcorp.com
Wed Nov 26 09:51:38 PST 2003
I'm already rewriting the query and using a binary cursor, reading binary data from the server is not a problem.
What I'd like to do is _send_ true binary data from the client to the server via PQexecParams(). This function can take parameters for a query (in my case the query is an update or insert). These parameters can be transferred in textual or binary format. I'd like to use the WKB of an update/insert query as a binary parameter to PQexecParams(). Unfortunately I will get the error message mentioned below.
I looked through postgis.sql and found the following definition of wkb:
CREATE TYPE wkb (
internallength = variable,
input = wkb_in,
output = wkb_out,
storage = extended,
send = bytea
What I would need in order to use PQexecParams() in the way I described it would be another parameter to the wkb type definition:
receive = wkb_from_binary,
There's already a send function, so a receive function would make a lot of sense from my point of view.
Similarly there's a cast function defined from wkb to bytea, but no cast from bytea to wkb. Adding this cast would make sense too, I think.
Martin
> -----Original Message-----
> From: David Blasby [mailto:dblasby at refractions.net]
> Sent: 26 November 2003 17:37
> To: PostGIS Users Discussion; strk
> Subject: Re: [postgis-users] GeomFromWkb() incomplete?
> Martin Schäfer wrote:
> > Hi,
> > I want to use GeomFromWkb() together with the PostgreSQL
> 7.4 function PQexecParams() for insert and update clauses.
> This would allow me to pass the WKB as real binary data and
> not just as a hex-encoded byte string. But I get the
> following error when I set the parameter format to binary:
> > ERROR: no binary input function available for type wkb
> > Is there something wrong with my installation, or is there
> really no binary input function for well known binary?
> (Sounds like a no-brainer to me.) Binary output seems to be
> supported as I can access AsBinary(the_geom) from a binary cursor.
> > Hexencoding on the client side, transmitting double the
> amount of bytes and hexdecoding on the server side is an
> unnecessary overhead, especially when dealing with geometries
> that contain tens of thousands of vertices.
> In order to truly transfeer binary data, you need to set up a binary
> cursor. Unfortunately, this is an all-or-nothing proposition -
> *everything* is in binary, not just your geometries.
> The nice thing about using the hex-ized WKB is that you can
> use it with
> the normal (text) cursor.
> An alternative (which I use with the postgis-Mapserver
> connector) is to
> re-write all your queries like this:
> SELECT a::text,b::text,c::text, asBinary(the_geom) FROM ...;
> If you use a binary cursor, you'll find its now behaving very
> much like
> a text cursor but its sending your geometry as true binary.
> I dont really like this method, but it does work well.
> 1. You have to pre-know all the columns you'll be asking for. You
> cannot use "SELECT *"...
> If you really want to make your application complex and
> your brain
> hurt, you can actually convert a "SELECT *" into a "SELECT a,b,c" by
> either looking at the system tables or executing a pseudo-query.
> For example, you can look in the system table (pg_class and
> pg_attribute
> I believe) to get the columns in a table. If you want to be even more
> abstract (and have it work on arbitrary SQL), you can::
> SELECT * FROM ( <query> as foo) WHERE false;
> This doesnt return any rows and is almost always very fast. When you
> look at the result set that libpq returns, you'll be able to fine all
> the column names and their types. From there, you just re-form your
> query like this:
> SELECT a::text,b::text,the_geom FROM <query> as foo;
> 2. not all types will have a convert-to-text function. You can get
> around this by directly calling the text output function
> associated with
> the type. This information is in the system tables.
> As you can see, it much easier to just use a text cursor and
> live with
> the to-hex-and-back overhead.
> I cannot imagine this being too much of an overhead. If you
> have some
> test numbers to show its big, you can encode the binary as Base64
> instead of Hex.
> dave
> postgis-users mailing list
