[postgis-users] GeomFromWkb() incomplete?
strk strk at keybit.net
Fri Nov 28 03:13:09 PST 2003
I've added definitions for wkb_from_binary.
You need latest CVS version for it. Please help testing it :)
If you want to keep your asset I think you can do the following:
CREATE FUNCTION wkb_recv(internal)
        RETURNS wkb
        AS '$libdir/libpostgis.so.0.8','WKB_recv'
        LANGUAGE 'C' WITH (isstrict);
UPDATE pg_type SET typreceive = 'wkb_recv'
	WHERE typname = 'wkb';
--strk;
Martin.Schaefer wrote:
> Hi,
> I'm already rewriting the query and using a binary cursor, reading binary data from the server is not a problem.
> What I'd like to do is _send_ true binary data from the client to the server via PQexecParams(). This function can take parameters for a query (in my case the query is an update or insert). These parameters can be transferred in textual or binary format. I'd like to use the WKB of an update/insert query as a binary parameter to PQexecParams(). Unfortunately I will get the error message mentioned below.
> I looked through postgis.sql and found the following definition of wkb:
> CREATE TYPE wkb (
> 	internallength = variable,
> 	input = wkb_in,
> 	output = wkb_out,
> 	storage = extended,
> 	send = bytea
> What I would need in order to use PQexecParams() in the way I described it would be another parameter to the wkb type definition:
> 	receive = wkb_from_binary,
> There's already a send function, so a receive function would make a lot of sense from my point of view.
> Similarly there's a cast function defined from wkb to bytea, but no cast from bytea to wkb. Adding this cast would make sense too, I think.
> Martin
> > -----Original Message-----
> > From: David Blasby [mailto:dblasby at refractions.net]
> > Sent: 26 November 2003 17:37
> > To: PostGIS Users Discussion; strk
> > Subject: Re: [postgis-users] GeomFromWkb() incomplete?
> > Martin Schäfer wrote:
> > > Hi,
> > > I want to use GeomFromWkb() together with the PostgreSQL
> > 7.4 function PQexecParams() for insert and update clauses.
> > This would allow me to pass the WKB as real binary data and
> > not just as a hex-encoded byte string. But I get the
> > following error when I set the parameter format to binary:
> > > ERROR: no binary input function available for type wkb
> > > Is there something wrong with my installation, or is there
> > really no binary input function for well known binary?
> > (Sounds like a no-brainer to me.) Binary output seems to be
> > supported as I can access AsBinary(the_geom) from a binary cursor.
> > > Hexencoding on the client side, transmitting double the
> > amount of bytes and hexdecoding on the server side is an
> > unnecessary overhead, especially when dealing with geometries
> > that contain tens of thousands of vertices.
> > In order to truly transfeer binary data, you need to set up a binary
> > cursor.  Unfortunately, this is an all-or-nothing proposition -
> > *everything* is in binary, not just your geometries.
> > The nice thing about using the hex-ized WKB is that you can
> > use it with
> > the normal (text) cursor.
> > An alternative (which I use with the postgis-Mapserver
> > connector) is to
> > re-write all your queries like this:
> > SELECT a::text,b::text,c::text, asBinary(the_geom) FROM ...;
> > If you use a binary cursor, you'll find its now behaving very
> > much like
> > a text cursor but its sending your geometry as true binary.
> > I dont really like this method, but it does work well.
> > 1. You have to pre-know all the columns you'll be asking for.  You
> > cannot use "SELECT *"...
> > 	If you really want to make your application complex and
> > your brain
> > hurt, you can actually convert a "SELECT *" into a "SELECT a,b,c" by
> > either looking at the system tables or executing a pseudo-query.
> > For example, you can look in the system table (pg_class and
> > pg_attribute
> > I believe) to get the columns in a table.  If you want to be even more
> > abstract (and have it work on arbitrary SQL), you can::
> >     SELECT * FROM ( <query> as foo) WHERE false;
> > This doesnt return any rows and is almost always very fast.  When you
> > look at the result set that libpq returns, you'll be able to fine all
> > the column names and their types.  From there, you just re-form your
> > query like this:
> > 	SELECT a::text,b::text,the_geom FROM <query> as foo;
> > 2. not all types will have a convert-to-text function.  You can get
> > around this by directly calling the text output function
> > associated with
> >   the type.  This information is in the system tables.
> > As you can see, it much easier to just use a text cursor and
> > live with
> > the to-hex-and-back overhead.
> > I cannot imagine this being too much of an overhead.  If you
> > have some
> > test numbers to show its big, you can encode the binary as Base64
> > instead of Hex.
> > dave
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
