[postgis-users] trying to implement a large (gnarly) SQL statement within a Map f ile
Menke, Kurt
kmenke at edac.unm.edu
Thu Oct 9 15:25:44 PDT 2003
I am developing a PHP client with MapServ 3.6 serving out data stored in
PostGIS. I have tabular and spatial census data in the same database in
PostgreSQL 7.3. I want to join the tabular data to the census tract feature
class but cannot figure out why my statement is not working. Below is the
data statement in my Map file and the error I receive.
Map File data statement
DATA "the_geom FROM
(SELECT
sum(nm00001.P001001) as total_pop,
nmgeo.COUNTY,
nmgeo.SUMLEV,
nmgeo.TRACT,
nmtract00.the_geom,
nmtract00.gid
FROM
nm00001
INNER JOIN nmgeo ON (nm00001.LOGRECNO =
nmgeo.LOGRECNO)
INNER JOIN nmtract00 ON (nmgeo.TRACT =
nmtract00.tract)
WHERE
(nmgeo.COUNTY = '035') AND
(nmgeo.SUMLEV = '158')
group by
nmgeo.TRACT,nmgeo.COUNTY,nmgeo.SUMLEV,nmgeo.TRACT,
nmtract00.the_geom,nmtract00.gid)
as foo using unique gid using SRID=-1"
Client error message
Warning: MapServer Error in prep_DB(): Error executing POSTGIS DECLARE (the
actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(oeh@)),'NDR'),gid::text from `YB7ÿ¿%
WHERE oeh@ && setSRID('BOX3D(350386.808620038
3527974.4288665,529613.191379962 3707025.5711335)'::BOX3D, -1 )'
Postgresql reports the error 'ERROR: parser: parse error at or near "" at
character 80 '
More Help:
Error with POSTGIS data variable. You specified '<check your .map file>'.
Standard ways of specifiying are :
(1) 'geometry_column from geometry_table'
(2) 'geometry_column from (<sub query>) as foo using unique <column name>
using SRID=<srid#>'
Make sure you put in the 'using unique <column name>' and 'using SRID=#'
clauses in.
For more help, please see http://postgis.refractions.net/documentation.php
Mappostgis.c - version of Nov 15/2002. in /var/www/cgi-bin/bber/bber.php on
line 421
Fatal error: Call to a member function on a non-object in
/var/www/cgi-bin/bber/bber.php on line 422
Thanks Kurt
Kurt A. Menke
GIS Analyst/Programmer
Mailing Address
Earth Data Analysis Center
MSC01 1110
1 University of New Mexico
Albuquerque, New Mexico 87131-0001
Street Address
Bandelier West, Room 123
Albuquerque, NM 87131
Phone: (505) 277-3622 (ext. 239)
FAX: (505) 277-3614
email: kmenke at edac.unm.edu
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20031009/b89503df/attachment.html>
