[postgis-users] Compilation error postgis_geos_wrapper.c
Paul Ramsey
pramsey at refractions.net
Tue Oct 14 09:18:09 PDT 2003
Does the const'ed version of GEOS currently compile and run all tests?
Paul
strk wrote:
> Here is a context diff
> --strk;
> ---8<-------------------------------------------------------------
> Index: postgis_geos_wrapper.cpp
> RCS file: /home/cvs/postgis/postgis/postgis_geos_wrapper.cpp,v
> retrieving revision 1.7
> diff -c -r1.7 postgis_geos_wrapper.cpp
> *** postgis_geos_wrapper.cpp 3 Oct 2003 16:45:37 -0000 1.7
> --- postgis_geos_wrapper.cpp 14 Oct 2003 09:34:33 -0000
> *** 102,110 ****
> extern "C" POINT3D *GEOSGetCoordinate(Geometry *g1);
> extern "C" POINT3D *GEOSGetCoordinates(Geometry *g1);
> extern "C" int GEOSGetNumCoordinate(Geometry *g1);
> ! extern "C" Geometry *GEOSGetGeometryN(Geometry *g1, int n);
> ! extern "C" Geometry *GEOSGetExteriorRing(Geometry *g1);
> ! extern "C" Geometry *GEOSGetInteriorRingN(Geometry *g1, int n);
> extern "C" int GEOSGetNumInteriorRings(Geometry *g1);
> extern "C" int GEOSGetSRID(Geometry *g1);
> extern "C" int GEOSGetNumGeometries(Geometry *g1);
> --- 102,110 ----
> ! extern "C" const Geometry *GEOSGetGeometryN(Geometry *g1, int n);
> ! extern "C" const Geometry *GEOSGetExteriorRing(Geometry *g1);
> ! extern "C" const Geometry *GEOSGetInteriorRingN(Geometry *g1, int n);
> *** 836,842 ****
> try{
> POINT3D *result = (POINT3D*) malloc (sizeof(POINT3D));
> ! Coordinate *c =g1->getCoordinate();
> result->x = c->x;
> result->y = c->y;
> --- 836,842 ----
> try{
> ! const Coordinate *c =g1->getCoordinate();
> result->x = c->x;
> result->y = c->y;
> *** 922,931 ****
> //call only on GEOMETRYCOLLECTION or MULTI*
> ! Geometry *GEOSGetGeometryN(Geometry *g1, int n)
> try{
> ! GeometryCollection *gc = (GeometryCollection *) g1;
> return gc->getGeometryN(n);
> catch(...)
> --- 922,931 ----
> ! const Geometry *GEOSGetGeometryN(Geometry *g1, int n)
> try{
> ! const GeometryCollection *gc = (GeometryCollection *) g1;
> catch(...)
> *** 936,942 ****
> //call only on polygon
> ! Geometry *GEOSGetExteriorRing(Geometry *g1)
> try{
> Polygon *p = (Polygon *) g1;
> --- 936,942 ----
> ! const Geometry *GEOSGetExteriorRing(Geometry *g1)
> try{
> *** 949,955 ****
> ! Geometry *GEOSGetInteriorRingN(Geometry *g1,int n)
> try{
> --- 949,955 ----
> ! const Geometry *GEOSGetInteriorRingN(Geometry *g1,int n)
> try{
> Horst.Duester wrote:
>>During compilation of PostGIS with GEOS the compilation process breaks with
>>the following error message:
>>c++ -O2 -Wall -Wmissing-prototypes -Wmissing-declarations -g -fexceptions
>>-I. -DFRO
>>NTEND -DSYSCONFDIR='"/home/hdus/local/etc/postgresql"' -DUSE_VERSION=72
>>-I/home/hdus
>>/local/include/geos -DUSE_GEOS -I../../src/include -c -o
>>postgis_geos_wrapper.o pos
>>postgis_geos_wrapper.cpp: In function `POINT3D *GEOSGetCoordinate
>>(geos::Geometry *)':
>>postgis_geos_wrapper.cpp:839: cannot convert `const geos::Coordinate *'
>>to `geos::Coordinate *' in initialization
>>postgis_geos_wrapper.cpp: In function `geos::Geometry *GEOSGetGeometryN
>>(geos::Geometry *, int)':
>>postgis_geos_wrapper.cpp:929: cannot convert `const geos::Geometry *'
>>to `geos::Geometry *' in return
>>*GEOSGetExteriorRing (geos::Geometry *)':
>>postgis_geos_wrapper.cpp:943: cannot convert `const geos::LineString *'
>>*GEOSGetInteriorRingN (geos::Geometry *, int)':
>>postgis_geos_wrapper.cpp:956: cannot convert `const geos::LineString *'
>>make: *** [postgis_geos_wrapper.o] Error 1
>>GEOS_20031014
>>Postgis-cvs from today
>>PostgreSQL 7.2.4
>>Any hint???
>>With best regards
>>Dr. Horst Düster
>>Leiter
>>Abteilung SO!GIS Koordination
>>Rötihof
>>4500 Solothurn
>>Tel.: 032 627 25 32
>>Fax: 032 627 22 14
>>horst.duester at bd.so.ch <mailto:horst.duester at bd.so.ch>
>>www.sogis.so.ch <http://www.sogis.so.ch/>
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
