[postgis-users] Dissolve obsolete polygon borders
David Blasby dblasby at refractions.net
Wed Oct 15 10:05:56 PDT 2003
David Blasby wrote:
> strk wrote:
>> Dave, could you make postgis_geos_wrapper.cpp catch GEOSException
>> to print a more meaningful error message when applicable ?
> Commited
oops - I spoke too soon.
Paul committed your "const" PostGIS patch.  Unfortunately, we are still
using the before-"const" GEOS.
I was really wishing to be able to hold off modifying PostGIS until GEOS
became stable again.
So, the CVS archive now has a version of the code that should work off
the "const" enabled GEOS.
I've attached a copy of postgis_wrapper.cpp that's compatible with the
pre-"const" GEOS.
dave
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20031015/c5b59c59/attachment.ksh>
