[postgis-users] UPDATE table to a joined query...
Mike Leahy
mgleahy at fes.uwaterloo.ca
Wed Oct 15 19:37:54 PDT 2003
Sorry - this was meant for the PGSQL users list...
Quoting Mike Leahy <mgleahy at fes.uwaterloo.ca>:
> Hello all,
> This question is related to updating tables - is there any way to calculate
> or
> update the values in a column in a table to the values in a field produced by
> a query result? An example of what I'm trying to do is below:
> update (tbl_ind_mananas LEFT JOIN (select count(*) as count, (dubicacion ||
> zona || manzana) as cod_manzana from tbl_censo_poblacion_1993 group by
> dubicacion, zona, manzana) tbl1 on relacion = cod_manzana) as tbl2 set
> poblacion = count;
> Basically I have a table (tbl_ind_manzanas) with a unique code (relacion)
> that
> can be linked to a field in the query result (cod_manzana). I want to update
> a field in the table with the count(*) result in the query. The update
> statement (as I have attempted it above) doesn't work...it seems that I can
> do
> nothing but directly update the values in a table. As soon as I try to
> supply
> anything other than just a table to the update statement, it doesn't like
> it.
> I'm sure others have experience with this issue...it seems to me that there
> would be many cases where such an approach would be useful. I'm hoping
> there's another method that I might be able to use that could accomplish
> essentially the same result. Any suggestions are greatly appreciated.
> Kind regards,
> Mike
> This mail sent through www.mywaterloo.ca
> postgis-users mailing list
