[postgis-users] Installation errors...
Azeem M. Suleman
suleman at cse.uta.edu
Fri Oct 17 11:20:41 PDT 2003
Hi All,
I have Redhat Linux 7.2 and i downloaded postgis-0.7.2 and i have PostgreSQL 7.1.3 already installed and working. But i don't have its source, so i downloaded postgresql-7.3.4 as source and then unzipped postgis-0.7.2 in the contrib directory. I then followed the step to compile the postgis-0.7.2.
1. make and got these errors:
root at descartes postgis-0.7.2]# make
gcc -O2 -Wall -Wmissing-prototypes -Wmissing-declarations -fpic -g -I. -I../../src/include -DFRONTEND -DSYSCONFDIR='"/usr/local/pgsql/etc"' -c -o postgis_gist.o postgis_gist.c
postgis_gist.c: In function `ggeometry_compress':
postgis_gist.c:104: structure has no member named `pred'
postgis_gist.c:114: structure has no member named `pred'
postgis_gist.c:120: structure has no member named `pred'
postgis_gist.c:126: warning: assignment makes integer from pointer without a cast
postgis_gist.c:130: warning: assignment makes integer from pointer without a cast
postgis_gist.c: In function `ggeometry_consistent':
postgis_gist.c:155: structure has no member named `pred'
postgis_gist.c:160: structure has no member named `pred'
postgis_gist.c:166: structure has no member named `pred'
postgis_gist.c: In function `rtree_union':
postgis_gist.c:338: structure has no member named `pred'
postgis_gist.c:343: structure has no member named `pred'
postgis_gist.c:331: warning: `tmp' might be used uninitialized in this function
postgis_gist.c: In function `rtree_penalty':
postgis_gist.c:364: structure has no member named `pred'
postgis_gist.c:368: structure has no member named `pred'
postgis_gist.c: In function `rtree_picksplit':
postgis_gist.c:406: structure has no member named `pred'
postgis_gist.c:408: structure has no member named `pred'
postgis_gist.c:453: structure has no member named `pred'
postgis_gist.c:455: structure has no member named `pred'
postgis_gist.c:459: structure has no member named `pred'
postgis_gist.c:461: structure has no member named `pred'
postgis_gist.c:499: structure has no member named `pred'
postgis_gist.c:524: warning: assignment makes integer from pointer without a cast
postgis_gist.c:525: warning: assignment makes integer from pointer without a cast
postgis_gist.c:379: warning: `datum_alpha' might be used uninitialized in this function
postgis_gist.c:379: warning: `datum_beta' might be used uninitialized in this function
make: *** [postgis_gist.o] Error 1
2. make install and same errors.
I didn't tried these after 2nd step.
3.createlang plpgsql yourtestdatabase
4.psql -d yourtestdatabase -f postgis.sql
5.psql -d yourtestdatabase -f spatial_ref_sys.sql
I would really appreciate if someone could help me out.
Thanks.
Regards,
Azeem.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20031017/c8ebdf14/attachment.html>
