[postgis-users] Insert performance issues
Nicolas RIBOT nri at scot.cnes.fr
Mon Oct 20 08:43:34 PDT 2003
> You said you have all the fields indexed involved in the
> query.  Exactly how
> many fields do you have indexed?
7. The table Structure is the following:
create table clcv1 (
    gid         serial primary key      ,
    AREA        float8                  ,
    PERIMETER   float8                  ,
    CLCV1_      int4                    ,
    CLCV1_ID    int4                    ,
    ID_CLC_INI  int4                    ,
    CLC_V0      int4                    ,
    CLC_V1      int4                    ,
    MARQUEUR    int4                    ,
    BLOC        varchar(4)              ,
    EDIT_ST     varchar(5)              ,
    MODIF_ST    varchar (6)             ,
    ID_BLOC     int4                    ,
    ISMODIF     int4          default 0
CREATE INDEX clcv1_spi   ON clcv1    USING GIST (the_geom
GIST_GEOMETRY_OPS);
CREATE index clcv1_clcv1__idx on clcv1 (clcv1_);
CREATE index clcv1_clc_v1_idx on clcv1 (clc_v1);
CREATE index clcv1_marqueur_idx on clcv1 (marqueur);
CREATE index clcv1_bloc_idx on clcv1 (bloc);
CREATE index clcv1_edit_st_idx on clcv1 (edit_st);
CREATE index clcv1_modif_st_idx on clcv1 (modif_st);
