[postgis-users] Insert performance issues
Obe, Regina DND\MIS
robe.dnd at ci.boston.ma.us
Mon Oct 20 09:37:41 PDT 2003
Almost forgot the join fields where you have lots of distinct values most
likely would need indexing.
-----Original Message-----
Sent: Monday, October 20, 2003 11:44 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Insert performance issues
> You said you have all the fields indexed involved in the
> query. Exactly how
> many fields do you have indexed?
7. The table Structure is the following:
create table clcv1 (
gid serial primary key ,
AREA float8 ,
PERIMETER float8 ,
CLCV1_ int4 ,
CLCV1_ID int4 ,
ID_CLC_INI int4 ,
CLC_V0 int4 ,
CLC_V1 int4 ,
MARQUEUR int4 ,
BLOC varchar(4) ,
EDIT_ST varchar(5) ,
MODIF_ST varchar (6) ,
ID_BLOC int4 ,
ISMODIF int4 default 0
CREATE INDEX clcv1_spi ON clcv1 USING GIST (the_geom
GIST_GEOMETRY_OPS);
CREATE index clcv1_clcv1__idx on clcv1 (clcv1_);
CREATE index clcv1_clc_v1_idx on clcv1 (clc_v1);
CREATE index clcv1_marqueur_idx on clcv1 (marqueur);
CREATE index clcv1_bloc_idx on clcv1 (bloc);
CREATE index clcv1_edit_st_idx on clcv1 (edit_st);
CREATE index clcv1_modif_st_idx on clcv1 (modif_st);
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
