[postgis-users] Problems with database creation
Daniel Vencler
daniel at geofoto.hr
Tue Oct 21 03:10:29 PDT 2003
Darren Houston wrote:
> Hello Daniel.
> There are no errors with your install. Those messages are normal. As I
> understand it, after the shell types (placeholders) are created, they
> are replaced with complete type definitions for you to then use.
> Darren H.
But when I try to run ogc test I get :
NOTICE: CREATE TABLE / PRIMARY KEY will create implicit index
'lakes_pkey' for table 'lakes'
ERROR: Type "linestring" does not exist
ERROR: Type "multilinestring" does not exist
ERROR: Type "multipolygon" does not exist
'bridges_pkey' for table 'bridges'
'buildings_pkey' for table 'buildings'
ERROR: Type "multipoylgon" does not exist
'named_places_pkey' for table 'named_places'
'map_neatlines_pkey' for table 'map_neatlines'
ERROR: Function polygonfromtext("unknown", integer) does not exist
Unable to identify a function that satisfies the given argument
types
You may need to add explicit typecasts
ERROR: Relation "road_segments" does not exist
ERROR: Relation "divided_routes" does not exist
ERROR: Relation "forests" does n You may need to add explicit
typecasts
ERROR: Relation "streams" does not exist
ERROR: Function pointfromtext("unknown", integer) does not exist
types
types
ERROR: Relation "ponds" does not exist
types
types
types
ot exist
types
I get simmilar errors when I try to import shape file with shp2pgsql.
Best regards,
Daniel Vencler
