[postgis-users] Insert performance issues
David Blasby dblasby at refractions.net
Thu Oct 23 09:06:38 PDT 2003
Jonathan W. Lowe wrote:
> What I'm wondering is if Mapserver will force use of an overlap (&&)
> that uses the index on parcel.the_geom, but prevents use of another
> index on parcel.apn.  Or, does the SQL within the parenthesis run
> independently of the surrounding "the_geom from (...) as listed_homes
> using unique oid using srid=26943" ?
> I ask in order to simulate the SQL for zoomed in Mapserver views for
> EXPLAIN tests on the PostgreSQL command line.
If you find its using the geometry index when you dont think it should
be, you can turn on the stats package.
I recently sent out a few messages on how to do this, but its basically:
1. make sure you compiled with USE_STATS=1 (in the makefile)
2) Verify that there's an entry in geometry_columns for your geometry column
3) execute "SELECT UPDATE_GEOMETRY_STATS();"
3) Verify that there's a big HISTOGRAM2D(...) in the geometry_columns
table for your data.
4) stats should now be enabled.  You'll find that the geometry index is
being used in a "wiser" way than before. Also, your EXPLAIN ANALYSE
estimated-number-of-rows should be much more accurate.
dave
