[postgis-users] Insert performance issues
    Paul Ramsey
    pramsey at refractions.net
    Thu Oct 23 10:24:46 PDT 2003
Mapserver always does its queries within the context of a bounding
rectangle, and this can in many cases cause suboptimal index usage by
PostGIS.  The way around this is to ensure you use the STATS extension
in PostGIS, so that the query planner can choose the correct index
every time.
The fact that your query is nested will not affect how the planner uses
indexes, it will look at the complete context of the query and figure
out the optimal plan given the knowledge it has.  If you have not
enabled STATS, it will always assume very high selectivity for spatial
indexes.  In the case of large bounding boxes, this selectivity
assumption will be wrong, and the result can be really stupid query
plans.  So the planner is very smart, but only within the context of
what it knows, and without STATS enabled, what it knows is sometimes
demonstrably incorrect.
P.
On Thursday, October 23, 2003, at 10:12 AM, chodgson at refractions.net
wrote:
>> What I'm wondering is if Mapserver will force use of an overlap (&&)
>> that uses the index on parcel.the_geom, but prevents use of another
>> index on parcel.apn.  Or, does the SQL within the parenthesis run
>> independently of the surrounding "the_geom from (...) as listed_homes
>> using unique oid using srid=26943" ?
      Paul Ramsey
      Refractions Research
      Email: pramsey at refractions.net
      Phone: (250) 885-0632
