[postgis-users] speed up spatial queries (distance() or intersects() or ???)
David Blasby dblasby at refractions.net
Fri Oct 24 09:46:48 PDT 2003
Daniel Faivre wrote:
> SELECT oid AS qoid FROM lg_annee WHERE  lga_annee='2003' and
> lga_nat_cdn=2 AND lga_geom && box3d((SELECT
> buf_geom FROM buffer WHERE type='zrb' )) AND distance(lga_geom, (SELECT
> buf_geom FROM buffer WHERE type='zrb' )) = 0;
Try enabling stats.
1. make sure you compiled with USE_STATS=1 (in the makefile)
2) Verify that there's an entry in geometry_columns for your geometry column
3) execute "SELECT UPDATE_GEOMETRY_STATS();"
3) Verify that there's a big HISTOGRAM2D(...) in the geometry_columns
table for your data.
4) stats should now be enabled.  You'll find that the geometry index is
being used in a "wiser" way than before. Also, your EXPLAIN ANALYSE
estimated-number-of-rows should be much more accurate.
Whats happening is postgresql is doing the spatial filtering on the
table too "early".
If this doesnt work, you might have to re-write your query so you are
using an actual GEOMETRY instead of "SELECT  buf_geom FROM buffer WHERE
type='zrb'".
dave
