[postgis-users] itemnquery limitation
Tom Melhuish
tmelhuish at webinsightsinc.com
Wed Sep 3 07:31:02 PDT 2003
Dave & Daniel,
I've open a Bugzilla ticket in Mapserver. The number is 418 and added all of
the attachments to recreate the problem. It's been active for a week an have
not seen any action on it.
I've downgraded Apache from 2.0.40 to Apache 1.3.20-16 from RH 7.2 and it
WORKS NOW!! I used RPMs to make the change an in doing so had to remove
Mod_perl & SSL because of dependencies. I definitely prefer to use Apache
2.0 since it comes with RH 8.0.
Thanks,
tom
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of
Daniel Morissette
Sent: Monday, August 25, 2003 5:30 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] itemnquery limitation
David Blasby wrote:
> Looks like the problem is in msReturnQuery(), msReturnPage(), or
> regcomp() - not in the postgis connector.
> DANIEL - do you see any reason why there would be a problem here?
Hard to tell what's wrong without being able to run this in tghe
debugger myself. The problem seems to appear here:
> #19 0x08057006 in msReturnPage (msObj=0x80c2008,
> html=0x1 <Address 0x1 out of bounds>, mode=0, papszBuffer=0x0)
> at maptemplate.c:2259
> #20 0x080577e7 in msReturnQuery (msObj=0x80c2008,
> pszMimeType=0x80a83d1 "text/html", papszBuffer=0x0) at
> maptemplate.c:2549
msReturnPage() is passed 'html=0x1' ... this should be the HTML
template, so it should be a pointer to a valid string buffer.
Since the line numbers don't match either the 4.0 or the 3.6.6 source I
couldn't tell exactly which call to msReturnPage() inside
msReturnQuery() fails (there are several calls). And anyway, even if
the problem manifests itself there, it is quite likely happening because
a layer or map object has been freed or corrupted somewhere else in the
code.
If you guys can package a reproduceable test case for this then perhaps
you can file it in the MapServer bugzilla and I can try to reproduce it.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
