Hi, Is there a way to test if a certain feature is within a polygon and not the bounding box of it with truly_inside and the like? Or I need to upgrade to the CVS version to use the GEOS contains() or within() functions? Thanks, -- Vinko Vrsalovic <el[|- at -|]vinko.cl> http://www.cprsig.cl
