[postgis-users] PostGis/MapServer ... Query-Problem
Elstermann, Mike
Mike.Elstermann at itc-halle.de
Fri Sep 12 05:07:39 PDT 2003
hi folks,
we need your help.
we wnt to query a postgis-layer with mapserver, but we get this error.
we have made the oid an the sql-statement is: "the_geom from punkte_tabelle
using unique oid using SRID=-1"
The Error:
<!-- MapServer version 3.6.6 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=TTF INPUT=TIFF INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
INPUT=SHAPEFILE --> <BODY BGCOLOR="#FFFFFF">
msPOSTGISLayerGetShape(): Query error. Error executing POSTGIS SQL
statement (in FETCH ALL): EXPLAIN VERBOSE SELECT * FROM punkte_tabelle
Error with POSTGIS data variable. You specified ''.<br> Standard ways of
specifiying are : <br>
(1) 'geometry_column from geometry_table' <br>
(2) 'geometry_column from (<sub query>) as foo using unique
<column name> using SRID=<srid#>' <br><br>
Make sure you put in the 'using unique <column name>' and 'using
SRID=#' clauses in.
Table punkte_tabelle with index punkte_tabelle_oid_idx (oid).
The Layer-Definition:
LAYER
CONNECTIONTYPE postgis
NAME pers_punkte
CONNECTION "user=postgres password=ppp dbname=test_db"
DATA 'the_geom from punkte_tabelle using unique oid using SRID=-1'
TYPE POINT
STATUS ON
HEADER
"/srv/www/htdocs/mapserver/test_mapplet/java/mapplet/halgis_pers_pkt_hea
der.html"
FOOTER "halgis_alle_footer.html"
CLASS
NAME 'Punkte'
TEMPLATE
"/srv/www/htdocs/mapserver/test_mapplet/java/mapplet/halgis_pers_pkt.htm
l"
OUTLINECOLOR 0 0 220
COLOR 0 0 220
SYMBOL 'circle'
size 12
END
END
Thanks very much!
::: mfg. Mike Elstermann [mikeE.], Teamleiter GIS/RIS, e-Solutions
::: IT-Consult Halle GmbH, Bornknechtstraße 5, 06108 Halle (Saale)
::: Sitz: Große Nikolaistraße 8
::: Tel.: +49 345 221 4237, Fax: +49 345 221 4236, mobil: +49 160 71 545 02
::: mike.elstermann at itc-halle.de ::: http://www.itc-halle.de
::: GeoDaten Online? -> http://www.itcgis.de
