[postgis-users] Loading only polygon with shp2pgsql
Matt Lynch
matt at terraEngine.com
Tue Sep 23 10:29:46 PDT 2003
Hi strk,
Thanks, that looks like exactly what I need!
I found it at
http://postgis.refractions.net/pipermail/postgis-users/2003-May/002477.h
tml.
Matt
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of strk
Sent: Tuesday, September 23, 2003 10:07 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Loading only polygon with shp2pgsql
Hi matt,
Some time ago I posted a patch to make shp2pgsql work whitout
accompaining
DBF. Might be used for your case.Search the archives for this subect:
Subject: [postgis-users] [PATCH] shp2pgsql without DBF
--strk;
matt wrote:
> Hi Randy,
> I have been a little skimpy on describing what I am doing, so here
> goes.
> I have an application which will allow users access to shape and
> raster data for a defined region. The region is specified by a
polygon.
> I am now writing a web app to handle the administration side. In the
> web app I allow administrators to upload shape files which then are
> loaded into a table. My problem is that I don't want to trust the
> administrators to not include attributes in the shape file. I
> anticipate the temptation to use existing shape files will be too
> great. So I would like to somehow extract only the polygon.
> Thanks,
> Matt
> Randy James
> Sent: Monday, September 22, 2003 11:18 AM
> Hi
> I would make your polygons a file without any attributes in its table
> and than use join to attach your attributes from another table. But
> i'm not sure if thats what you are looking for.
> Cheers
> Randy
> --- Matt Lynch <matt at terraEngine.com> wrote:
> > Hi,
> > I am wondering if there is a way for me to load the
> > polygon information
> > from a shape file only (i.e. without attribute data)?
> > I am currently using shp2pgsql with -a to append to a table, but
> > want to avoid problems if I append a shape file with a new
> > attribute associated.
> > Thanks,
> > Matt
> > Outgoing mail is certified Virus Free.
> > Checked by AVG anti-virus system
> > (http://www.grisoft.com).
> > Version: 6.0.515 / Virus Database: 313 - Release Date: 9/1/2003
> > postgis-users mailing list postgis-users at postgis.refractions.net
> Do you Yahoo!?
> Yahoo! SiteBuilder - Free, easy-to-use web site design software
> http://sitebuilder.yahoo.com
> Incoming mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
