[postgis-users] FW: [Psycopg] RELEASE: GeoTypes-0.2.0a1
Norman Vine nhv at cape.com
Wed Sep 24 17:01:53 PDT 2003
FYI
> -----Original Message-----
> From: psycopg-bounces at lamu.initd.org
> [mailto:psycopg-bounces at lamu.initd.org]On Behalf Of Richard Taylor
> Sent: Wednesday, September 24, 2003 10:47 AM
> To: psycopg at lamu.initd.org
> Subject: [Psycopg] RELEASE: GeoTypes-0.2.0a1
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> I have just put up the beginnings of an implementation of the OpenGIS types as
> an extension to the GeoTypes package.
> I have the type registration working and an implementation of the Point type
> (called OGPoint). Skeletons of the rest of the class hierachy are there as
> well but are empty at present.
> For those that are interested in having an early look and influencing the
> implementation you can download it from here:
> 	 http://people.initd.org/rjt/GeoTypes-0.2.0a1.tar.gz
> There are a couple of things that are worth noting and discussing:
> 1) I have named all the OpenGIS classes with a OG prefix, so Point is OGPoint
> and Geometry is OGGeometry etc. I don't like this very much but there are
> name clashes between the standard Postgresql geometric types and the OpenGIS
> ones and I wanted to keep a single package. Does anyone have any other
> suggestions as to how to deal with this?
> 2) All the OpenGIS types (there are seven of them) have the same type oid.
> They are implemented as subclasses of the same (GEOMETRY) base class. To deal
> with this I have registered a factory class against the type oid and the
> factory class works out, from the string returned by the database, which
> subclass to create. This looked like a reasonable design to me, does anyone
> have any other suggestions?
> 3) Because the Geometry type is added to postgres on a database by database
> basis its type oid is different for each database. I dynamically work out
> what the type oid is by creating a table with a Geometry field and querying
> the oid of that field. I have a feeling that I should be able to get the type
> oid without creating the table. Does anyone know how to do this?
> Enjoy
> Richard
> Jabber: RichardTaylor at jabber.org
> PGPKey: http://search.keyserver.net:11371/pks/lookup?op=get&search=0xA7DA9FD9
> Key fingerprint = D051 A121 E7C3 485F 3C0E  1593 ED9E D868 A7DA 9FD9
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.2.3 (GNU/Linux)
> iD8DBQE/ca5W7Z7YaKfan9kRAkj0AJ0bJaS1XJPUUIDV9faJaKgo+n9IPACg2RdW
> eI5JEQZL0cZ9lKAoOct+qfw=
> =3oWH
> -----END PGP SIGNATURE-----
> Psycopg mailing list
> Psycopg at lists.initd.org
> http://lists.initd.org/mailman/listinfo/psycopg
