[postgis-users] multi-column index w/ btree & gist
Charlton Purvis cpurvis at asg.sc.edu
Thu Sep 25 20:28:50 PDT 2003
Hi, folks:
I poked around on the discussion lists here as well as in pgsql land,
and I don't have a clear picture on making multi-column indexes.
If my table looks like this:
sea_coos_model=# \d bari_um;
                    Table "bari_um"
   Column    |            Type             | Modifiers
 ubari       | double precision            |
 vbari       | double precision            |
 file_date   | date                        |
 time_index  | integer                     |
 time_stamp  | timestamp without time zone |
 the_geom    | geometry                    |
 speed       | double precision            |
 theta       | double precision            |
 label_theta | double precision            |
 label_speed | integer                     |
 label_char  | character(1)                |
 xi          | double precision            |
 yi          | double precision            |
I'd like to create an index something like this:
create index bari_um__multi on bari_um using btree(time_stamp),
gist(the_geom);
No doubt that doesn't work.  But is there a way for me to do this?  Some
multi-column indexing stuff appears here,
http://www.sai.msu.su/~megera/postgres/gist/, but perhaps that is old?
Bottom line is that I want to tell the db to look for the time_stamp
before making any georeferenced comparisons.
Thanks,
Charlton
Charlton Purvis
(803) 777-8858 : voice
(803) 777-8833 : fax
cpurvis at sc.edu
Advanced Solutions Group
Department of Physics and Astronomy
University of South Carolina
Columbia, SC 29208
