[postgis-users] [PATCH] shp2pgsql and ''::numeric
strk
strk at keybit.net
Mon Sep 29 05:13:05 PDT 2003
I fixed some bugs in shp2pgsql.c:
- "\t" always preceeded the first value of a dump_format query
if NULL
- field values where quoted with (") in dump_format when
called with -k ( did I introduce that? )
- Appropriate calls to DBF[..]ReadAttributes based on
cached attribute types.
- Assured that *all* shapes are NULL before exiting with
an error ( I did not check that NULL shapes in the midle
of the shapefiles are handled, but previous code did
not check that either ... )
As a side effect - trying to make it more readable - I reduced some
lines of code and changed the format a bit. I'm sorry if this causes
an harder merging process...
pramsey wrote:
> It is also worth pointing out that the int/bigint determination code
> seems to be deciding on bigint an awful lot. bigint shouldn't be used
> unless the field definition is number(9,0) or higher.
> strk wrote:
> > shp2pgsql (as of latest cvs version)
> > generates empty strings as the values for numeric fields.
> > If you could use DBFReadAttribute instead of DBFReadStringAttribute
> > you might get a better control over values.
> > What I think is that the field value is the number 0, so
> > DBFIsAttributeNULL returns false while DBFReadStringAttribute
> > returns '' ( the empty string! ).
> > Can you please check this (it requires duplicating the type
> > detecting code used at table creation time ( or maybe cache
> > that info).
> > NOTE that the problem emerge only for numerics valued 0.
> > TIA
> > --strk;
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> __
> | Paul Ramsey
> | Refractions Research
> | Email: pramsey at refractions.net
> | Phone: (250) 885-0632
> \_
--- shp2pgsql.c.000 Sat Sep 27 03:04:29 2003
+++ shp2pgsql.c Mon Sep 29 13:58:53 2003
@@ -89,4 +89,5 @@
char opt;
char *col_names;
+DBFFieldType *types;
int Insert_attributes(DBFHandle hDBFHandle, int row);
@@ -465,43 +466,58 @@
//Insert the attributes from the correct row of dbf file
-int Insert_attributes(DBFHandle hDBFHandle, int row){
- int i,num_fields;
- num_fields = DBFGetFieldCount( hDBFHandle );
- for( i = 0; i < num_fields; i++ ){
- if(DBFIsAttributeNULL( hDBFHandle, row, i)){
- if(dump_format){
- printf("\t\\N");
- }else{
- if(i == 0){
- printf("NULL");
- }else{
- printf(",NULL");
- }else{
- if (dump_format){
- if ( quoteidentifiers ){
- if(i == 0){
- printf("\"%s\"",make_good_string((char*)DBFReadStringAttribute( hDBFHandle,row, i )) );
- }else{
- printf("\t\"%s\"",make_good_string((char*)DBFReadStringAttribute( hDBFHandle,row, i )) );
- }else{
- if(i == 0){
- printf("%s",make_good_string((char*)DBFReadStringAttribute( hDBFHandle,row, i )) );
- }else{
- printf("\t%s",make_good_string((char*)DBFReadStringAttribute( hDBFHandle,row, i )) );
- }else{
- if(i == 0){
- printf("'%s'",protect_quotes_string((char*)DBFReadStringAttribute(hDBFHandle, row, i )) );
- }else{
- printf(",'%s'",protect_quotes_string((char*)DBFReadStringAttribute(hDBFHandle, row, i )) );
+int
+Insert_attributes(DBFHandle hDBFHandle, int row)
+ int i,num_fields;
+ char val[1024];
+ num_fields = DBFGetFieldCount( hDBFHandle );
+ for( i = 0; i < num_fields; i++ )
+ if(DBFIsAttributeNULL( hDBFHandle, row, i))
+ if(dump_format)
+ if(i) printf("\t");
+ printf("\\N");
+ else
+ if(i) printf(",");
+ printf("NULL");
+ else /* Attribute NOT NULL */
+ switch (types[i])
+ case FTString:
+ if ( -1 == snprintf(val, 1024, "%s",
+ DBFReadStringAttribute(hDBFHandle, row, i)) )
+ fprintf(stderr, "Warning: field %d name trucated\n", i);
+ val[1023] = '\0';
+ break;
+ case FTInteger:
+ sprintf(val, "%d", DBFReadIntegerAttribute(hDBFHandle, row, i));
+ break;
+ case FTDouble:
+ sprintf(val, "%f", DBFReadDoubleAttribute(hDBFHandle, row, i));
+ break;
+ default:
+ fprintf(stderr,
+ "Error: field %d has invalid or unknown field type (%d)\n",
+ i, types[i]);
+ exit(1);
+ if (dump_format) {
+ if ( i ) printf("\t");
+ printf("%s",make_good_string(val));
+ } else {
+ if ( i ) printf(",");
+ printf("'%s'",protect_quotes_string(val));
@@ -699,7 +715,9 @@
num_records = DBFGetRecordCount(hDBFHandle);
names = malloc((num_fields + 1)*sizeof(char*));
+ types = (DBFFieldType *)malloc((num_fields + 1)*sizeof(char*));
for(j=0;j<num_fields;j++){
type = DBFGetFieldInfo(hDBFHandle, j, name, &field_width, &field_precision);
names[j] = malloc ( strlen(name)+1);
+ types[j] = type;
strcpy(names[j], name);
for(z=0; z < j ; z++){
@@ -756,10 +774,13 @@
SHPGetInfo( hSHPHandle, &num_entities, &phnshapetype, &padminbound[0], &padmaxbound[0]);
- if(obj == NULL){
- obj = SHPReadObject(hSHPHandle,0);
- if(obj == NULL){
- printf("file exists but contains null shapes");
- exit(-1);
+ j=num_entities;
+ while(obj == NULL && j--)
+ obj = SHPReadObject(hSHPHandle,j);
+ if ( obj == NULL)
+ fprintf(stderr, "Shapefile contains %d NULL object(s)\n", num_entities);
+ exit(-1);
