[postgis-users] Union as an aggregate
David Blasby dblasby at refractions.net
Mon Sep 29 17:28:52 PDT 2003
strk wrote:
> Dave, I made no special 'unite' code, just sql create command:
> CREATE AGGREGATE unite (
> 	sfunc = GeomUnion,
> 	basetype = geometry,
> 	stype = geometry
Hum - this shouldnt do anything.
The aggregate should have "null" as its initial value.
GeomUnion(null,<geometry>) --> null.
So, you'll end up with null *very* quickly because
GeomUnion(null,<geometry>) returns null without any actual execution.
Are you running this on a big table?  At worst I'd expect this to use up
memory the same size all the geometries in the table.
I'll look more at this tomorrow.
dave
ps. just as a test, try redefining your unite to:
  	sfunc = GeomUnion,
  	stype = geometry,
         initial_condition = '<wkt>'
Where <wkt> is the well known text of one of the geometries in your
table.  This will force the initial function to be:
GeomUnion(<wkt>,<geometry>) --> <geometry>
And things might work.  If this does work, then the problem is that the
postgresql aggregate function code isnt paying attention to the
"isstrict" tags on the base ("geomUnion") function.
