[postgis-users] Point data type
Joel Gwynn joelman at joelman.com
Sat Apr 3 13:49:22 PST 2004
So, if I'm using postgis, which seems to have its own constructs for
dealing with geometry, should I bother creating a point column using the
data from my lat/long columns, or will I be better off  using
AddGeometryColumn?
Paul Ramsey wrote:
> Depends on what your goal is, mais oui.
> Actual postgis types can be spatially indexed, can be operated on by
> the handy spatial analysis and testing functions, reprojection, etc.
> Fields are just fields. If you are only planning on reading the values
> out, never querying them for spatial info or testing their spatial
> properties, then the spatial objects have no particular advantage.
> Paul
> On Saturday, April 3, 2004, at 06:31 AM, Joel Gwynn wrote:
>> I'm sort of feeling my way in the dark here.  I have some GIS
>> experience (Arcview, AutoCAD Map), and some database experience
>> (MySQL, SQL-Server), but these tools (PostGIS, Mapserver) are new to me.
>> I have data with lat/long fields, and I've brought in a shapefile
>> (from TIGER data).  I haven't done anything with it yet, but I have
>> some questions.
>> 1.   I've noticed that postgres has point and line data types.  Is
>> there any advantage to creating a point field and using that instead
>> of individual lat/long fields?
>> 2.   Ditto for lines.
>    Paul Ramsey
>      Refractions Research
>      Email: pramsey at refractions.net
>      Phone: (250) 885-0632
> postgis-users mailing list
