[postgis-users] postgis build problem
Paul Ramsey
pramsey at refractions.net
Tue Apr 6 19:57:55 PDT 2004
Looks like you have Proj4 support enabled (USE_PROJ = 1) but have not
installed Proj...
On Tuesday, April 6, 2004, at 06:57 PM, dkittler at customerportfolios.com
wrote:
> i am building postgis (latest cvs tarball) on SuSE 9 professional with
> postgres 7.4.2 and i am getting the following error when running
> 'make'.
> postgis_transform.c:55:22: projects.h: No such file or directory
> postgis_transform.c:58: error: parse error before '*' token
> postgis_transform.c:58: warning: type defaults to `int' in declaration
> of `make_project'
> postgis_transform.c:58: warning: data definition has no type or storage
> class
> postgis_transform.c:62: error: parse error before '*' token
> postgis_transform.c:67: error: parse error before '*' token
> postgis_transform.c:70: warning: no previous prototype for
> `pj_transform_nodatum'
> postgis_transform.c: In function `pj_transform_nodatum':
> postgis_transform.c:74: error: `pj_errno' undeclared (first use in this
> function)
> postgis_transform.c:74: error: (Each undeclared identifier is reported
> only once
> postgis_transform.c:74: error: for each function it appears in.)
> postgis_transform.c:76: error: `point_offset' undeclared (first use in
> this function)
> postgis_transform.c:79: error: `srcdefn' undeclared (first use in this
> function)
> postgis_transform.c:81: error: `point_count' undeclared (first use in
> this function)
> postgis_transform.c:83: error: `XY' undeclared (first use in this
> function)
> postgis_transform.c:83: error: parse error before "projected_loc"
> postgis_transform.c:84: error: `LP' undeclared (first use in this
> function)
> postgis_transform.c:86: error: `projected_loc' undeclared (first use in
> this function)
> postgis_transform.c:86: error: `x' undeclared (first use in this
> function)
> postgis_transform.c:87: error: `y' undeclared (first use in this
> function)
> postgis_transform.c:89: error: `geodetic_loc' undeclared (first use in
> this function)
> postgis_transform.c:89: warning: implicit declaration of function
> `pj_inv'
> postgis_transform.c:98: error: `dstdefn' undeclared (first use in this
> function)
> postgis_transform.c:102: error: parse error before "projected_loc"
> postgis_transform.c:108: warning: implicit declaration of function
> `pj_fwd'
> postgis_transform.c: In function `to_rad':
> postgis_transform.c:128: error: `PI' undeclared (first use in this
> function)
> postgis_transform.c: In function `to_dec':
> postgis_transform.c:139: error: `PI' undeclared (first use in this
> function)
> postgis_transform.c: At top level:
> postgis_transform.c:146: error: parse error before '*' token
> postgis_transform.c:147: warning: return type defaults to `int'
> postgis_transform.c: In function `make_project':
> postgis_transform.c:152: error: `PJ' undeclared (first use in this
> function)
> postgis_transform.c:152: error: `result' undeclared (first use in this
> function)
> postgis_transform.c:182: warning: implicit declaration of function
> `pj_init'
> postgis_transform.c: In function `transform_geom':
> postgis_transform.c:200: error: `PJ' undeclared (first use in this
> function)
> postgis_transform.c:200: error: `input_pj' undeclared (first use in
> this
> function)
> postgis_transform.c:200: error: `output_pj' undeclared (first use in
> this function)
> postgis_transform.c:200: warning: left-hand operand of comma expression
> has no effect
> postgis_transform.c:253: error: `pj_errno' undeclared (first use in
> this
> function)
> postgis_transform.c:264: warning: implicit declaration of function
> `pj_free'
> postgis_transform.c:290: warning: implicit declaration of function
> `pj_transform'
> postgis_transform.c:305: warning: implicit declaration of function
> `pj_strerrno'
> postgis_transform.c:305: warning: format argument is not a pointer (arg
> 4)
> postgis_transform.c:346: warning: format argument is not a pointer (arg
> 4)
> make: *** [postgis_transform.o] Error 1
> any help on this matter is greatly appreciated.
> -derrick
> postgis-users mailing list
Paul Ramsey
Refractions Research
Email: pramsey at refractions.net
Phone: (250) 885-0632
