[postgis-users] loading data into postgres
strk
strk at keybit.net
Wed Apr 7 04:49:40 PDT 2004
What version of postgis is installed in 'yourtestdatabase' ?
What verison of postgis created the postgis.sql you are trying to source ?
--strk;
On Wed, Apr 07, 2004 at 07:10:31AM -0400, dkittler at customerportfolios.com wrote:
> the command 'psql -d yourtestdatabase -f postgis.sql'
> creates the follwing console output:
> psql:postgis.sql:1022: ERROR: could not find function "centroid" in
> file "/usr/local/pgsql/lib/libpostgis.so.0.8"
> psql:postgis.sql:1027: ERROR: current transaction is aborted, commands
> ignored until end of transaction block
> psql:postgis.sql:1032: ERROR: current transaction is aborted, commands
> psql:postgis.sql:1043: ERROR: current transaction is aborted, commands
> and for the command: psql -d yourtestdatabase -f spatial_ref_sys.sql
> i get the same transaction aborted message.
> when i do a show all on the database i see some data structures ...
> name | setting
> add_missing_from | on
> australian_timezones | off
> authentication_timeout | 60
> check_function_bodies | on
> checkpoint_segments | 3
> checkpoint_timeout | 300
> checkpoint_warning | 30
> client_encoding | SQL_ASCII
> client_min_messages | notice
> but when i try to do a select against any of them i get
> a 'relationship' does not exist error.
> again, your help is greatly appreciated.
> -derrick
> postgis-users mailing list
