[postgis-users] GML vs SVG {-5.2}
Sean Montague
SMontague at oaconsulting.com
Wed Apr 7 09:35:22 PDT 2004
This is where I am getting confused. I read in places that people are using xslt to display GML as SVG. Are these people not reading the data from a database? Storing the data as GML and displaying it as SVG. Which if this is a case, then to read directly from a database like postgreSQL and PostGIS, GML is a wasted step if the ultimate format is SVG. What I'd really like is a caparison of GML vs SVG, if it is appropriate. SVG is very powerful and I know it well. I've written apps that query a MySQL database and have customized some tools. I'm just trying to figure out if I should learn GML. Is there something about GML that is an advantage over SVG? Thanks.
>>> pramsey at refractions.net 04/07/04 10:08AM >>>
Sean Montague wrote:
> I have made many a map with SVG, but I'm new to PostGIS. So new in
> fact that I haven't even installed it yet. I've been using MySQL,
> but have come to the conclusion that postgreSQL is the way to go.
> So, for those of you familiar with both SVG and GML, can you explain
> the relationship between the two, it seems they are not mutually
> exclusive, and why wouldn't I write directly to SVG if a map ends up
> in SVG anyway? I'm trying to sort through all this to determine the
> direction I should go in. Thanks.
If you are determined to write out SVG then certainly GML gives you
nothing in terms of advantage. If you are building a more generic
infrastructure, then a WFS (web feature server that serves GML) on top
of your database can provide a nice generic API to your underlying data.
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
