[postgis-users] geometryfromtext problem
Joel Gwynn
joelman at joelman.com
Sat Apr 10 07:42:17 PDT 2004
I'm having trouble doing something I've done before. I've got a
geometry column, but for some reason I can't populate it. I have a lat
field and a long field (both floats) that i'm trying to use to populate
the_geom like so:
update locations set the_geom=GeometryFromText('POINT (' || cast(long as
varchar(10)) || ' ' || cast(lat as varchar(10)) || ')', -1);
which yields:
ERROR: Function 'geometryfromtext(varchar, int4)' does not exist
Unable to identify a function that satisfies the given argument
types
You may need to add explicit typecasts
I've tested GeometryFromText with a generic string like so:
select GeometryFromText('POINT (-69.97844 41.929119)',-1);
which works:
geometryfromtext
SRID=-1;POINT(-69.97844 41.929119)
(1 row)
and I'm pretty sure my geometry column is defined correctly:
Table "locations"
Column | Type | Modifiers
lat | double precision | not null
long | double precision | not null
the_geom | geometry |
Check constraints: "$1" (srid(the_geom) = -1)
"$2" ((geometrytype(the_geom) = 'POINT'::text) OR
(the_geom IS NULL))
I think I'm just not building the WKT point string correctly.
