[postgis-users] NZMG/lat long srid value?
Wood Brent
pcreso at pcreso.com
Sun Apr 11 15:44:49 PDT 2004
--- Paul Ramsey <pramsey at refractions.net> wrote:
> If you are going to memorize any EPSG code, let it be 4326, as it is
> used as a default SRS for many OpenGIS web service specifications.
> SELECT * FROM SPATIAL_REF_SYS WHERE SRID = 4326;
> The spatial_ref_sys.sql file appears to have definitions for some NZ
> stuff, but not all the new ones I found in the proj epsg file.
> SELECT * FROM SPATIAL_REF_SYS WHERE SRTEXT LIKE '%Zealand%';
Thanks,
appreciated!
