[postgis-users] Side Location Conflict
Markus Schaber
schabios at logi-track.com
Mon Apr 19 02:00:13 PDT 2004
During debugging one of our apps, I discovered the following problem:
It seems that I have valid geometry data as input:
logigis=# SELECT distinct
isvalid(intersection(buffer(geom,'0.00005'),'BOX3D (8.554829000000002
47.370963,8.573829 47.379963000000004)'::box3d)) from badgeoms;
isvalid
t
(1 Zeile)
However, trying to union those valid geometries, I get the following
error message:
logigis=# SELECT geomunion(intersection(buffer(geom,'0.00005'),'BOX3D
(8.554829000000002 47.370963,8.573829 47.379963000000004)'::box3d)) from
badgeoms;
NOTICE: TopologyException: side location conflict (8.56235,47.3777)
ERROR: GEOS union() threw an error!
I attached the output of "COPY badgeoms TO stdout;" so you can try to
reproduce the problem.
I use a postgis debian package created by a co-worker of mine that
identifies itsself as postgis 0.8.1, the output of postgis_version is:
logigis=# select postgis_version();
postgis_version
0.8 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
(1 Zeile)
Can anyone reproduce or explain the problem? Is there a workaround or
fix available?
Thanks,
Markus
markus schaber | dipl. informatiker
logi-track ag | rennweg 14-16 | ch 8001 zürich
phone +41-43-888 62 52 | fax +41-43-888 62 53
mailto:schabios at logi-track.com | www.logi-track.com
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20040419/470474d5/attachment.ksh>
