[postgis-users] pgsql2shp errors out after upgrading to 0.8.1
Paul Ramsey pramsey at refractions.net
Mon Apr 19 18:36:56 PDT 2004
Mark,
If you could do the debug routine as strk outlines below and send him
the SQL, it will help us kill this bug for future versions.
Thanks,
Paul
strk wrote:
> On Sun, Apr 18, 2004 at 10:04:57PM -0500, markc at weaponeer.com wrote:
> (cuts)
>>markc at linux:~/qgis-0.1> pgsql2shp -b gis_main us_plant_rad_x
>>Initializing... Done.
>>ERROR:  syntax error at or near ""::text,"" at character
>>1121
> You should try to get the entire query.
> Uncomment around line 312 in pgsql2shp.c and see what is the query.
> Note that the -b switch tries to cast every attribute to a text,
> except the geometries. Also try without the -b switch.
> --strk;
> postgis-users mailing list
       __
      | Paul Ramsey
      | Refractions Research
      | Email: pramsey at refractions.net
      | Phone: (250) 885-0632
      \_
