[postgis-users] PostGIS and JUMP driver
Chris Faulkner christopher.faulkner at ntlworld.com
Wed Apr 21 09:44:41 PDT 2004
Thanks. The postgis driver works quite nicely for me with Postgis 0.8.1,
JUMP 1.1.1 on cygwin. I had a problem with the class loader but it
turned out that Oracle (!) had put it's own JRE in the path before the
one I thought was there and wanted to use (JDK 1.4.1).
Perhaps I should do that doc/INSTALL.txt myself !
Chris
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Astrid Emde (CCGIS)
> Sent: 21 April 2004 11:50
> To: PostGIS Users Discussion
> Subject: AW: [postgis-users] PostGIS and JUMP driver
> Hello Chris,
> we use Jump 1.0 to load PostGIS Tables in JUMP. We made the
> experience that it works only with Jump 1.0. (see links
> http://postgis.refractions.net/download.php )
> # english version ---------------------
> --> PostGIS plug in for JUMP 1.0. you get on the PostGIS Homepage
> --> see: http://postgis.refractions.net/  and
> http://postgis.refractions.net/download.php for more information
> --> Installation PostGIS plug in for JUMP 1.0. !!!!
> 1.) copy postgisdriver-1.0-src-20031215.jar in directory Jump 1.0
> 2.) copy pg74jdbc3.jar in directory lib
> 3.) copy postgisdriver-1.0.jar in Verzeichnis ext
> # german version ---------------------
> --> PostGIS plug in fur JUMP 1.0. erhaltlich auf der PostGIS Web-Seite
> --> URL's: http://postgis.refractions.net/  bzw.
> --> Installation PostGIS plug in fur JUMP 1.0.
> 1.) postgisdriver-1.0-src-20031215.jar in Verzeichnis Jump
> 1.0 kopieren.
> 2.) pg74jdbc3.jar in Verzeichnis lib kopieren.
> 3.) postgisdriver-1.0.jar in Verzeichnis ext kopieren.
> WICHTIG:  --- PostGIS plug in funktioniert nur fur Version
> JUMP 1.0. --- # german version ---------------------
> I hope an can help you with this information. Good luck!
> Astrid
> -----Ursprungliche Nachricht-----
> Von: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net]Im
> Auftrag von Chris Faulkner
> Gesendet: Mittwoch, 21. April 2004 10:17
> An: 'PostGIS Users Discussion'
> Betreff: [postgis-users] PostGIS tables and JUMP driver
> Hello
> I asked about the PostGIS driver for JUMP a few days back.
> Does anyone have the doc/INSTALL.txt that I am looking for ?
> I tried with JUMP 1.1 rather than 1.1.1. I am on JUMP 1.1 /
> Postgres 7.3.4 ?
> Do I have to alter and recompile the JUMP source to get the
> plugin working ?
> I'd really like to see this working - any help would be very useful !
> Thanks
> Chris
> > From: Chris Faulkner [mailto:christopher.faulkner at ntlworld.com]
> > Sent: 18 April 2004 12:47
> > To: 'PostGIS Users Discussion'
> > Subject: JUMP driver
> > Hello all
> > I have installed JUMP 1.1.1 and the postgis driver jars in
> the lib/ext
> > directory. The README.txt says For installation instructions see
> > doc/INSTALL.txt. But there is no doc directory. Any ideas anyone ?
> > Thanks
> > Chris
> postgis-users mailing list postgis-users at postgis.refractions.net
