[postgis-users] Re: Fwd: pgsql2shp errors out after upgrading to 0.8.1
markc at weaponeer.com
Wed Apr 21 19:09:25 PDT 2004
This seems ok with the changes in place.
/qgis-0.1> pgsql2shp -b gis_main us_states
Initializing... Done.
MAINSCAN: SELECT
"gid"::text,"area"::text,"state_name"::text,"state_fips"::text,"sub_region"::text,"state_abbr"::text,"pop2000"::text,"pop2001"::text,"pop00_sqmi"::text,"white"::text,"black"::text,"ameri_es"::text,"asian"::text,"hawn_pi"::text,"other"::text,"mult_race"::text,"hispanic"::text,"males"::text,"females"::text,"age_under5"::text,"age_5_17"::text,"age_18_21"::text,"age_22_29"::text,"age_30_39"::text,"age_40_49"::text,"age_50_64"::text,"age_65_up"::text,"med_age"::text,"med_age_m"::text,"med_age_f"::text,"households"::text,"ave_hh_sz"::text,"hsehld_1_m"::text,"hsehld_1_f"::text,"marhh_chd"::text,"marhh_no_c"::text,"mhh_child"::text,"fhh_child"::text,"families"::text,"ave_fam_sz"::text,"hse_units"::text,"vacant"::text,"owner_occ"::text,"renter_occ"::text,"no_farms97"::text,"avg_size97"::text,"crop_acr97"::text,"avg_sale97"::text,asbinary("the_geom",
'NDR') FROM "us_states"
Dumping: XX [51 rows].
markc at linux:~/qgis-0.1> pgsql2shp -b gis_main us_plant_rad_x
MAINSCAN: SELECT
"tapefile"::text,"doelab"::text,"ornlid"::text,"site"::text,"replc"::text,"lat"::text,"long"::text,"state"::text,"quad"::text,"mapcode"::text,"study"::text,"phase"::text,"basinid"::text,"b_lat_c"::text,"b_long_c"::text,"samptyp"::text,"osamptyp"::text,"sampdat"::text,"samphr"::text,"sampler"::text,"grabs"::text,"weather"::text,"airtemp"::text,"sampodor"::text,"smpcolr"::text,"sgeounit"::text,"sedtype"::text,"strwdth"::text,"strdpth"::text,"wtrlevel"::text,"strflow"::text,"strorder"::text,"vegtype"::text,"vegdens"::text,"relief"::text,"contamc"::text,"plantno"::text,"dtreetyp"::text,"coniftyp"::text,"bushtyp"::text,"mosstyp"::text,"algaetyp"::text,"trnkdiam"::text,"plnthght"::text,"tapedata"::text,"spcdat"::text,"batch_es"::text,"asbatch"::text,"ubatch_dn"::text,"ubatch_fl"::text,"ubatch_ms"::text,"ubatch_xx"::text,"u_xx_mthd"::text,"u_xx_ppm"::text,"u_dn_ppm"::text,"u_fl_ppm"::text,"u_ms_ppm"::text,"ag_ppm"::text,"al_pct"::text,"as_ppm"::text,"b_ppm"::text,"ba_ppm"::text,"be_ppm"::text,"ca_ppm"::text,"co_ppm"::text,"cr_ppm"::text,"cu_ppm"::text,"fe_pct"::text,"li_ppm"::text,"mg_pct"::text,"mn_ppm"::text,"mo_ppm"::text,"na_pct"::text,"nb_ppm"::text,"ni_ppm"::text,"p_pct"::text,"pb_ppm"::text,"pt_ppm"::text,"sc_ppm"::text,"se_ppm"::text,"th_ppm"::text,"ti_ppm"::text,"v_ppm"::text,"y_ppm"::text,"zn_ppm"::text,"zr_ppm"::text,"methods"::text,"reformat"::text,"comments"::text,"comment2"::text,asbinary("us_plant_rad_x_geom",
'NDR') FROM "us_plant_rad_x"
Dumping: XXXXXXXXXXXXXXXXXXX [1720 rows].
This would have errored out, or segfaulted before + 32.
Cheers!
Mark
---- Original message ----
>Date: Wed, 21 Apr 2004 09:39:19 +0200
>From: strk <strk at keybit.net>
>Subject: Re: Fwd: pgsql2shp errors out after upgrading to
0.8.1
>To: markc at weaponeer.com
>Cc: postgis-users at postgis.refractions.net
>Try modifying around line 2667 of pgsql2shp.c
>Memory is allocated for main_scan_query, I belive
the ::text cast
>part was not taken into account, and indeed when not
specifying
>-b that part is not written to the buffer...
>I've made those lines look like this:
> tmpint = strlen(table)+2;
> for (i=0; i<mainscan_nflds; i++)
> tmpint += strlen(mainscan_flds[i])+32;
> main_scan_query = (char *)malloc(tmpint+256);
>Please tell me if the segfault and error message go away.
>--strk;
>On Tue, Apr 20, 2004 at 06:36:26PM -0500,
markc at weaponeer.com wrote:
>> Here you go -- I see a garble in the query right before
>> the column mentioned in the message. Every error of this
>> type seems to mention 1121 as the first offending char
(with
>> different tables) ?
us_plant_rad_x
>> MAINSCAN: SELECT
"tapefile"::text,"doelab"::text,"ornlid"::text,"site"::text,"replc"::text,"lat"::text,"long"::text,"state"::text,"quad"::text,"mapcode"::text,"study"::text,"phase"::text,"basinid"::text,"b_lat_c"::text,"b_long_c"::text,"samptyp"::text,"osamptyp"::text,"sampdat"::text,"samphr"::text,"sampler"::text,"grabs"::text,"weather"::text,"airtemp"::text,"sampodor"::text,"smpcolr"::text,"sgeounit"::text,"sedtype"::text,"strwdth"::text,"strdpth"::text,"wtrlevel"::text,"strflow"::text,"strorder"::text,"vegtype"::text,"vegdens"::text,"relief"::text,"contamc"::text,"plantno"::text,"dtreetyp"::text,"coniftyp"::text,"bushtyp"::text,"mosstyp"::text,"algaetyp"::text,"trnkdiam"::text,"plnthght"::text,"tapedata"::text,"spcdat"::text,"batch_es"::text,"asbatch"::text,"ubatch_dn"::text,"ubatch_fl"::text,"ubatch_ms"::text,"ubatch_xx"::text,"u_xx_mthd"::text,"u_xx_ppm"::text,"u_dn_ppm"::text,"u_fl_ppm"::text,"u_ms_ppm"::text,"ag_ppm"::text,"al_pct"::text,"as_ppm"::text,"b_ppm"::text,"ba_ppm"::text,"be_ppm"::text,"ca_ppm"::text,"co_ppm"::text,"cr_ppm"::text,"cu_ppm"::text,"fe_pct"::ted®#@d®#@pm"::text,"mg_pct"::text,"mn_ppm"::text,"mo_ppm"::text,"na_pct"::text,"nb_ppm"::text,"ni_ppm"::text,"p_pct"::text,"pb_ppm"::text,"pt_ppm"::text,"sc_ppm"::text,"se_ppm"::text,"th_ppm"::text,"ti_ppm"::text,"v_ppm"::text,"y_ppm"::text,"zn_ppm"::text,"zr_ppm"::text,"methods"::text,"reformat"::text,"comments"::text,"comment2"::text,asbinary("us_plant_rad_x_geom",
>> ERROR: syntax error at or near ""::text,"" at character
>> 1121
>> There is another error we have seen with "-b" a
segfault.
>> Here is query. I see nothing obvious here -- obvious to
to
>> me at least. This is a ARC supplied .shp that was
imported,
>> and it also behaves well without "-b".
>> MAINSCAN: SELECT
>> Dumping: XSegmentation fault
>> Tomorrow I may fire this up using gdb and see what I can
see
>> Cheers, and Honestly -- thanks for all the great work!
If I
>> was not so old as to require at least 4 hours sleep -- I
>> would roll up my sleeves and help a bit more....
>> Mark
>> >Date: Tue, 20 Apr 2004 07:52:21 +0200
to
>> 0.8.1
>> >On Mon, Apr 19, 2004 at 08:21:36PM -0500,
>> >> This ended up being the "-b" option, we have never
used
>> it
>> >> before -- and I have no idea as to why it was decided
to
>> try
>> >> it now.
>> >> We have happy .shp output even with 3M rows.
>> >> Thanks for the keen eye!
>> >> Mark
>> >Mark, nonetheless I'd like to see the "incriminated"
query,
>> >because 'syntax error' is not an error I'd expect from
>> pgsql2shp,
>> >even with the -b switch. What I expect is a 'Cannot
>> cast...' or
>> >similar. Could you please send that main_loop_query ?
>> >TIA
>> >--strk;
>> >> Date: Sun, 18 Apr 2004 22:04:57 -0500
>> >> From: markc at weaponeer.com
>> >> X-Mailer: Webmail Mirapoint Direct 3.2.2-GA
>> >> Subject: pgsql2shp errors out after upgrading to 0.8.1
>> >> To: postgis-users at postgis.refractions.net
>> >> Hello,
>> >> I've used pgsql2shp many times with this database,
>> after
>> >> upgrading to 0.8.1 I am getting an odd cast error.
>> >> Postgres is 7.4.2, using bison-1.875 (the
problem ??),
>> >> PostGIS is using gdal-1.2.0 (proj-4.4.7).
>> >> Also if I import a .shp of this made in 1-2004
(which
>> >> seems to work) it dies with another syntax error.
>> >> I can send a dump of this db, as it's reasonably
small.
>> >> Thanks,
>> >> Mark
>> us_plant_rad_x
character
>> >> 1121
>> >> markc at linux:~/qgis-0.1> psql -d gis_main
>> >> Welcome to psql 7.4.2, the PostgreSQL interactive
>> terminal.
>> >> Type: \copyright for distribution terms
>> >> \h for help with SQL commands
>> >> \? for help on internal slash commands
>> >> \g or terminate with semicolon to execute query
>> >> \q to quit
>> >> gis_main=# select * from us_plant_rad_x;
>> >> gis_main=#
>> >> gis_main=# select version();
>> >> version
>> >> PostgreSQL 7.4.2 on i686-pc-linux-gnu, compiled by
GCC
>> gcc
>> >> (GCC) 3.3.1 (SuSE Linux)
>> >> (1 row)
