[postgis-users] manipulate vs analysis
Robert W. Burgholzer
rburghol at vt.edu
Fri Apr 23 04:18:58 PDT 2004
Following is my take on your question, although I don;t know the strict
definition:
In postgresql/postgis, as in any SQL implementation, everything can be viewed
as analysis, unless ones explicitly uses an update statement.
Thus, SELECT is analysis, UPDATE is manipulation.
But, this is just me,
r.b.
>===== Original Message From sd at dil.in, PostGIS Users Discussion
<postgis-users at postgis.refractions.net> =====
>Dear users
>can someone clarify the difference between manipulate and analysis !!
>Manipulate should genreally mean changing the data and analying would mean
>investigating.
>So when we talk about Buffereing and Overlaying, does it come as part of
>analysis or manipulate.
>Or if someone can explain the both terms with the help of any examples !!
>Many Thanks
>Saurabh
>___________________________________________________________________
>Saurabh Data
>School of Computing
>University of Leeds
>Leeds LS2 9JT
>U.K.
>one who seeketh , will findeth and all door shall open - james Allen
>Express yourself with cool new emoticons http://www.msn.co.uk/specials/myemo
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
rburghol at veetee dot edu
History of Nutrition: "Buddha probably consumed a high-carb diet."
