[postgis-users] Re: ArcGIS connection with PostGIS
Tyler Mitchell
TMitchell at lignum.com
Thu Apr 29 09:50:21 PDT 2004
Jan,
There has been some initial work on an extension done, in VB, by one
group. It has been updated by a few others, but provides a decent ability
to extract data from PostGIS into an ArcMap layer and stores enough
metadata to allow you to edit the file and post it back into PostGIS,
replacing the table with the updated info.
This project is called PgArc - located at:
http://sourceforge.net/projects/pgarc/ or http://pgarc.sourceforge.net/
I can add you to the developers list if you want to continue discussions
there.
A side group has been working on developing a PostgreSQL ole db connector
which can serve as a basis for read and write connectivity directly with
the database using, from what I understand, a more standard ArcMap
component.
The website for this project appears to be down, but you can find it on:
http://gborg.postgresql.org/
I highly recommend building on this previous work or at least building on
the Ole db connector work, rather than using ODBC. If interested, this is
worthy of more discussion on the pgarc mailing list or one that you may
have for your project. I am interested in helping coordinate bringing the
two projects together. Feel free to also contact my off list to discuss.
Tyler
gdal-dev-admin at remotesensing.org wrote on 04/29/2004 05:36:15 AM:
> Hello,
> We are a company that is creating a GIS for geologic purposes using
> open-source software solutions. Currently we have a PostgreSQL database
> running with the PostGIS extension. In order to view and edit spatial
data
> we use ArcGIS from ESRI.
> It appears however that connecting to a PostGIS table with ArcGIS is
quite
> difficult.
> The current option for us is to develop a new extension to ArcGIS so
that
> the PostGIS possibilities become available, but this is a daunting task
so
> we would like to check beforehand if some efforts have been made
recently on
> this issue appearing regularly on several opensource GIS forums. It is
most
> likely that we are going to use Delphi as primary development language
and
> where needed we will use Visual C++. For PostgreSQL connectivity we are
> probably going to use ODBC or native Delphi components in combination
with
> the GDAL library of Frank Warmerdam. If there is somebody here that is
also
> working on such a project it might be interesting to get in contact and
> discuss the development process. For everybody who is also interested in
> such an application, please contact us so that we can see if we can meet
> your needs too.
> Greetings,
> Jan Boonen
> Zoutewelle Media Groep b.v
> Department of software development
> The Netherlands
> E-mail: janb at zmg.nl
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
