PINKTOMATE ha scritto: > HI evereybody could you help me about the syntax of the command ogr2ogr > to convert a shapefile in a XML or XML code Simple! With "ogr2ogr --help" you obtain all the possible command. To trasform a ESRI Shape file into a GML (so XML) you must use this syntax: ogr2ogr output_file.gml -f "GML" input_file.shp
