[postgis-users] other errors during postgis.sql command
Benedetto Porfidia
benedetto.porfidia at fastwebnet.it
Tue Aug 10 09:39:58 PDT 2004
Hallo All
I have installed postgis on latest postgres sources with no errors
and all seem to be gone ok.
but when I try the psql command i have these similar errors to the
previous message.
I tried to drop the db, run ldconfig with the path found with "find
/-name libpostgis.so.0.8", create a new db,
run createlang.... ,but i have the same error.
postgres at bumbum:/home/jodalap$ /usr/local/pgsql/bin/psql -d gis_db -f
/usr/pg_data/postgis.sql
BEGIN
message
PL/PgSQL is installed.
(1 row)
psql:/usr/pg_data/postgis.sql:47: NOTICE: type "histogram2d" is not yet
definedDETAIL: Creating a shell type definition.
psql:/usr/pg_data/postgis.sql:47: ERROR: could not load library
"/usr/local/pgsql/lib/libpostgis.so.0.8":
/usr/local/pgsql/lib/libpostgis.so.0.8: undefined symbol: pj_get_release
psql:/usr/pg_data/postgis.sql:52: ERROR: current transaction is
aborted, commands ignored until end of transaction block
.etc etc (the same for all lines) and
commit
please, someone can give some help
thanks
