[postgis-users] other errors during postgis.sql command
Benedetto Porfidia
benedetto.porfidia at fastwebnet.it
Tue Aug 10 10:43:40 PDT 2004
J.D.
thanx a lot, but:
TECHER Jean David wrote:
>>I tried to drop the db, run ldconfig with the path found with "find
>>/-name libpostgis.so.0.8",
>The path must be done for proj et geos
I have both in /usr/local/lib (libproj.so.0 and libgeos.so)
so I did
echo /usr/local/lib >>/etc/ld.so.conf
and ldconfig
I dropped the last db i created a new one, I made createlang
and when i try psql there is the same error
> create a new db,
>>run createlang.... ,but i have the same error.
>>postgres at bumbum:/home/jodalap$ /usr/local/pgsql/bin/psql -d gis_db -f
>>/usr/pg_data/postgis.sql
>>BEGIN
>> message
>> PL/PgSQL is installed.
>>(1 row)
>>psql:/usr/pg_data/postgis.sql:47: NOTICE: type "histogram2d" is not yet
>>definedDETAIL: Creating a shell type definition.
>>psql:/usr/pg_data/postgis.sql:47: ERROR: could not load library
>>"/usr/local/pgsql/lib/libpostgis.so.0.8":
>>/usr/local/pgsql/lib/libpostgis.so.0.8: undefined symbol: pj_get_release
>>psql:/usr/pg_data/postgis.sql:52: ERROR: current transaction is
>Did you install PROJ et replace in /usr/pg_data/postgis.sql '$libdir' by the
>path to the
>libpostgis.so.0.8 path ???
I simply made a "mv /home/etc
etc_______/postgrsql...../contrib/postgis_cvs/postgis.sql
that is where I did initdb first
>>aborted, commands ignored until end of transaction block
>>.etc etc (the same for all lines) and
>>commit
>>please, someone can give some help
>>thanks
>>_______________________________________________
>>postgis-users mailing list
>>postgis-users at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-users
I don't know what to do anymore,
I compiled proj and geos first -downloaded into home dir- and all is
gone without error messages,
then i configured (as default) and compiled postgresql from the same
home dir,
then i finally did make and make install to postgis-cvs from
home/bla..bla/postgresql..blabla/contrib/postgis
compilation ended normally, so i did mkdir /usr/pg_data as root
chown postgres /usr/pg_data
su postgres
started postmasrter -D to pg_data and -i (for tcp)
initdb
and.... (see the top)
thanx again
B.P.
