[postgis-users] PostgreSQL 8.0 Beta Installer for Windows
strk strk at keybit.net
Fri Aug 13 04:33:24 PDT 2004
On Fri, Aug 13, 2004 at 01:55:02PM +0300, Steffen Macke wrote:
> > 1. HOW TO USING POSTGIS
> > before create any database using PostGIS that users should replace in the
> > file "share\contrib\postgis.sql"
> > 	'$libdir'
> > by the path to PostgreSQL installation (ex: C:/Postgresql ... and so
> > on....)
> For me it works using $libdir. Is it really required to enter the path?
> What's the experience of other people?
> If it's required, the replacement should be done by the installer.
I've no experience under windows, but $libdir should work.
If it doesn't it should be investigated why.
--strk;
> > 2. AsSVG function and our names
> > 	Since there is the function AsSVG() avalable in this distribution (see
> > http://svg.cc/pg/assvg/ for details) just add my name TECHER Jean David
> > 	and KLAUS FOERSTER who has done this function...
> Thanks for pointing this out.
> Steffen
> postgis-users mailing list
