[postgis-users] Postgres 8.0beta1 crashes when SELECTing using GISTindex?
Steffen Macke
sdteffen at web.de
Sun Aug 15 21:36:01 PDT 2004
Dan,
>The immediately following script (taken directly from
>http://postgis.refractions.net/README.postgis.txt) also causes a crash in
>the PostgreSQL 8.0beta1
I can reproduce your crashes (also using Windows PostgreSQL 8.0-beta1
and the
Windows PostGIS installer).
I first thought this might be the problem of linking the GEOS library
again, but
this seems to be a different one. The installer uses the binaries
provided by Jean David Techer -
maybe other people who build native Windows PostGIS can check the scripts
highlighted by Dan and share the results of the tests with the mailing
list.
Eventually some PostgreSQL configure options are enough to overcome the
problem.
Steffen
