[postgis-users] Postgres 8.0beta1 crashes when SELECTing usingGISTindex?
strk
strk at keybit.net
Mon Aug 16 02:36:50 PDT 2004
Jean, please try postgis CVS, as a pg75/80 fix was applied right
after 0.8.2 release.
--strk;
On Mon, Aug 16, 2004 at 11:25:33AM +0200, TECHER Jean David wrote:
> Hi Dan and Steffen,
> I redo the compilation for PostgreSQL using 0.8.2 with the snapshot pf
> postgresql 09 August 2004
> I used patchs from Marc CAVE AYLAN and ROMI HARDIYANTO...
> It seems that from file 'postgis_estimate.c' I have the problem
> error: .. has no structure name 'data' on line 1000
> #if DEBUG_GEOMETRY_STATS
> elog(NOTICE, "postgis_gist_sel called");
> #endif
> * Find the constant part
> -----> other = (Const *) lfirst(args);
> if ( ! IsA(other, Const) )
> self = (Var *)other;
> other = (Const *) lsecond(args);
> else
> Does strk or Marc any idea on how to solve this problem ????
> TECHER JEAN DAVID
> - Responsable Informatique 01MAP -
> e-mail:davidtecher at yahoo.fr
> Tel: 06 85 37 36 75
> Site PostGIS: http://techer.pascal.free.fr/postgis/index.htm
> > -----Message d'origine-----
> > De : postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net]De la part de
> > Steffen Macke
> > Envoye : lundi 16 aout 2004 06:36
> > A : PostGIS Users Discussion
> > Objet : Re: [postgis-users] Postgres 8.0beta1 crashes when SELECTing
> > usingGISTindex?
> > Dan,
> > >The immediately following script (taken directly from
> > >http://postgis.refractions.net/README.postgis.txt) also causes a crash in
> > >the PostgreSQL 8.0beta1
> > I can reproduce your crashes (also using Windows PostgreSQL 8.0-beta1
> > and the
> > Windows PostGIS installer).
> > I first thought this might be the problem of linking the GEOS library
> > again, but
> > this seems to be a different one. The installer uses the binaries
> > provided by Jean David Techer -
> > maybe other people who build native Windows PostGIS can check the scripts
> > highlighted by Dan and share the results of the tests with the mailing
> > list.
> > Eventually some PostgreSQL configure options are enough to overcome the
> > problem.
> > Steffen
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
