[postgis-users] New tests for PostGIS binairy from CVS 17 august 2004
TECHER Jean David
davidtecher at yahoo.fr
Tue Aug 17 05:11:10 PDT 2004
Hi guys
I compiled postgresql from CVS of 17 august 2004 for postgresql and postgis
too...
I compiled with GEOS 1.0.0, PROJ 4.4.7, AsSVG()
I made some test from PostgreSQL from CVS 20040817 not from pginstaller of
pgfoundary
I not yet released the zip file...Next time...
>From a DOS prompt
I... CREATE A POSTGIS DATABASE
C:\WINDOWS\system32>createdb testgis
CREATE DATABASE
C:\WINDOWS\system32>createlang plpgsql testgis
C:\WINDOWS\system32>cd c:\postgres75_win32_postgis_082
C:\postgres75_win32_postgis_082>psql -d testgis -c "\i share/postgis.sql"
.....Lot of CREATE FUNCTION
share/spatial_ref_sys.sql"
....Lots of INSERT
All works fine...OK
II...TRY TESTS FROM README.postgis + AsSVG funtion
I tryed SQL from README.postgis + AsSVG():
CREATE TABLE geom_test ( gid int4, geom geometry,name varchar(25) );
INSERT INTO geom_test ( gid, geom, name )
VALUES ( 1, 'POLYGON((0 0 0,0 5 0,5 5 0,5 0 0,0 0 0))', '3D Square');
VALUES ( 2, 'LINESTRING(1 1 1,5 5 5,7 7 5)', '3D Line' );
VALUES ( 3, 'MULTIPOINT(3 4,8 9)', '2D Aggregate Point' );
SELECT * from geom_test WHERE geom && 'BOX3D(2 2 0,3 3 0)'::box3d;
INSERT INTO SPATIAL_REF_SYS
( SRID, AUTH_NAME, AUTH_SRID, SRTEXT ) VALUES
( 1, 'EPSG', 4269,
'GEOGCS["NAD83",
DATUM[
"North_American_Datum_1983",
SPHEROID[
"GRS 1980",
6378137,
298.257222101
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]]'
CREATE TABLE geotest (
id INT4,
name VARCHAR(32)
SELECT AddGeometryColumn('testgis','geotest','geopoint',1,'POINT',2);
INSERT INTO geotest (id, name, geopoint)
VALUES (1, 'Olympia', GeometryFromText('POINT(-122.90 46.97)',1));
VALUES (2, 'Renton', GeometryFromText('POINT(-122.22 47.50)',1));
SELECT name,AsText(geopoint),assvg(geopoint) FROM geotest;
It gave me:
C:\postgres75_win32_postgis_082>psql -d testgis -f
c:\postgis_validation\test1.s
ql
CREATE TABLE
INSERT 43956 1
INSERT 43957 1
INSERT 43958 1
psql:c:/postgis_validation/test1.sql:8: NOTICE: postgis_gist_sel called
psql:c:/postgis_validation/test1.sql:8: NOTICE: No statistics, returning
defau
lt estimate
gid | geom | name
1 | SRID=-1;POLYGON((0 0 0,0 5 0,5 5 0,5 0 0,0 0 0)) | 3D Square
2 | SRID=-1;LINESTRING(1 1 1,5 5 5,7 7 5) | 3D Line
(2 rows)
psql:c:/postgis_validation/test1.sql:23: ERROR: duplicate key violates
unique c
onstraint "spatial_ref_sys_pkey"
CREATE TABLE
psql:c:/postgis_validation/test1.sql:30: NOTICE: Invalid schema name -
using cu
rrent_schema()
CONTEXT: SQL query "SELECT AddGeometryColumn('', $1 , $2 , $3 , $4 , $5 ,
$6 )
PL/pgSQL function "addgeometrycolumn" line 4 at select into variables
addgeometrycolumn
public.geotest.geopoint SRID:1 TYPE:POINT
geometry_column fixed:0
(1 row)
INSERT 43968 1
INSERT 43969 1
name | astext | assvg
Olympia | POINT(-122.9 46.97) | cx="-122.9" cy="-46.97"
Renton | POINT(-122.22 47.5) | cx="-122.22" cy="-47.5"
(2 rows)
III. ...LOADING SHAPEFILES AND CREATE INDEX from shp2pgsql
>From my own shapefiles, I did
createdb diren_geostat
createlang plpgsql diren_geostat
psql -d diren_geostat -c "\i
c:/postgres75_win32_postgis_082/share/postgis.sql"
c:/postgres75_win32_postgis_082/share/spatial_ref_sys.sql"
shp2pgsql -s 27582 -D
"C:\donnees_sig\statcom2\statcom\myshapefiletemp\APB_LR.shp" apb_lr
diren_geostat | psql diren_geostat
psql -d diren_geostat -c "create index apb_lr_index_spatial on apb_lr using
gist(the_geom gist_geometry_ops)"
"C:\donnees_sig\statcom2\statcom\myshapefiletemp\znieff_lr_type2.shp"
znieff_lr_type2 diren_geostat | psql diren_geostat
psql -d diren_geostat -c "create index znieff_lr_type2_index_spatial on
znieff_lr_type2 using gist(the_geom gist_geometry_ops)"
vacuumdb diren_geostat
All works fine too... :-)
IV... AsSVG and others functions
All works fine :)
TECHER JEAN DAVID
- Responsable Informatique 01MAP -
e-mail:davidtecher at yahoo.fr
Tél: 06 85 37 36 75
Site PostGIS: http://techer.pascal.free.fr/postgis/index.htm
