[postgis-users] Mulitple Geometry Columns in One Table
strk
strk at keybit.net
Wed Aug 18 01:32:32 PDT 2004
Mark, I've just committed a change similar to what you're proposing.
Constraints will be named:
enforce_srid_<fieldname>
enforce_geomtype_<fieldname>
If you want to help you might try modifying
rename_geometry_table_constraints().
I've spent some time on it and finally I've decided to obsolete it.
No functions currently rely on constraints name so having constraints
with unconsistent names should not be a problem.
The problem in finding out column name from
rename_geometry_table_constraints() is that consrc might be in
the following forms:
((geometrytype(the_geom) == ....
((geometrytype("MyGeom") == ....
((geometrytype(public."MyGeom") == ....
((geometrytype("MySchema"."MyGeom") == ....
((geometrytype("MySchema".the_geom) == ....
AFAICS there's no reference to the field being checked in pg_constraint
so I tried using substr (7.1 compatible).
The only viable way I see is using CASE statements, but I'm not sure
we can rely on future values in connsrc for this to work.
Sorry for the inconveniences.
--strk;
On Wed, Aug 18, 2004 at 08:39:54AM +0100, Mark Cave-Ayland wrote:
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net] On
> > Behalf Of Steffen Macke
> > Sent: 18 August 2004 07:32
> > To: PostGIS Users Discussion
> > Subject: [postgis-users] Mulitple Geometry Columns in One Table
> > Hello All,
> > previously (up to PostGIS 0.8.0), it was possible to have
> > more than one geometry column in a table. With the current
> > CVS version this is impossible (postgis.sql.in version 1.74).
> > AddGeometryColumn() fails reporting an error that the constraint
> > "enforce_srid"
> > already exists.
> > After commenting out the following 4 lines in
> > AddGeometryColumn(), adding a second geometry column works again:
> > EXECUTE 'ALTER TABLE ' ||
> > quote_ident(real_schema) || '.' || quote_ident(table_name)
> > || ' ADD CONSTRAINT enforce_srid CHECK (SRID(' ||
> > quote_ident(column_name) ||
> > ') = ' || new_srid || ')' ;
> > Is it possible to check for existence of the constraint
> > before? Or does
> > it make more sense
> > to include the geometry column name in the constraint name (e.g.
> > enforce_shape_srid)?
> > Regards,
> > Steffen
> Hi Steffen,
> Good spot. I think that the best thing would be to include the geometry
> column in the constraint name, so that when you query the table in psql
> it is easy to spot which constraint belongs to which column. Could you
> try replacing the table checks section in postgis.sql with the following
> instead:
> -- Add table checks
> EXECUTE ''ALTER TABLE '' ||
> quote_ident(real_schema) || ''.'' ||
> || '' ADD CONSTRAINT enforce_'' || column_name ||
> ''_srid CHECK (SRID('' || quote_ident(column_name) ||
> '') = '' || new_srid || '')'' ;
> IF (not(new_type = ''GEOMETRY'')) THEN
> ''_geotype CHECK (geometrytype('' ||
> quote_ident(column_name) || '')='' ||
> quote_literal(new_type) || '' OR ('' ||
> quote_ident(column_name) || '') is null)'';
> END IF;
> If this works for you, I'll commit the change into CVS.
> Kind regards,
> Mark.
> Mark Cave-Ayland
> Webbased Ltd.
> Tamar Science Park
> Derriford
> Plymouth
> PL6 8BX
> England
> Tel: +44 (0)1752 764445
> Fax: +44 (0)1752 764446
> This email and any attachments are confidential to the intended
> recipient and may also be privileged. If you are not the intended
> recipient please delete it from your system and notify the sender. You
> should not copy it or use it for any purpose nor disclose or distribute
> its contents to any other person.
> postgis-users mailing list
--===============0819578935==--
> > Hello All,
> > "enforce_srid"
> > already exists.
> > before? Or does
> > it make more sense
> > Regards,
> > Steffen
> Hi Steffen,
> instead:
> -- Add table checks
> END IF;
> Kind regards,
> Mark.
> Mark Cave-Ayland
> Webbased Ltd.
> Tamar Science Park
> Derriford
> Plymouth
> PL6 8BX
> England
